ESP-IDF OSX issue with cmake
cjd7734
Postby cjd7734 » Sun Dec 08, 2019 5:58 am
Hello everyone, I am trying to get the ESP-IDF to work in a new install of eclipse
I can build and flash on the command line using the idf.py commands
but I am unable to get the eclipse environment to build
I get this error output
Errors occurred during the build.
Errors running builder 'CDT Core Builder' on project 'test1'.
Building test1
Cannot run program "/Users/calvin/esp32/esp-idf/tools/cmake" (in directory "/Users/calvin/eclipse-workspace/test1/build"): error=13, Permission denied
Building test1
The cmake executable is located at
which cmake
/opt/local/bin/cmake
in the /Users/calvin/esp32/esp-idf/tools/ folder this is a cmake dir but not a cmake executable
is this just a path problem ?
echo $path
/Users/calvin/esp32/esp-idf/components/esptool_py/esptool
/Users/calvin/esp32/esp-idf/components/espcoredump
/Users/calvin/esp32/esp-idf/components/partition_table/
/Users/calvin/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin
/Users/calvin/.espressif/tools/xtensa-esp32s2-elf/esp-2019r2-8.2.0/xtensa-esp32s2-elf/bin
/Users/calvin/.espressif/tools/esp32ulp-elf/2.28.51.20170517/esp32ulp-elf-binutils/bin
/Users/calvin/.espressif/tools/openocd-esp32/v0.10.0-esp32-20190708/openocd-esp32/bin /Users/calvin/.espressif/python_env/idf4.1_py2.7_env/bin
/Users/calvin/esp32/xtensa-esp32-elf/bin /opt/local/bin /opt/local/sbin
/usr/local/bin /usr/bin /bin /usr/sbin /sbin
I think I am close
Thank You
Calvin
Users browsing this forum: No registered users and 124 guests
