have progressed, apparently there is an issue with xtensa-esp32-elf-gdb.exe, and one needs to set an environment variable TERM to value xterm i.e.
set "TERM=xterm"
So i now have this, gdb connects to the
Error: No symbols for FreeRTOS
Warn : Failed to send data to device: LIBUSB_ERROR_TIMEOUT.
Error: Sending data to device timed out.
Error: transport_write() failed: timeout occurred.
Error: jaylink_jtag_io() failed: timeout occurred.
Warn : Last read operation left 2048 bytes.
Warn : cpu0: Failed reading 5844 bytes at address 0x40090000
Error: no working area available, can't alloc space for stub code!
Error: Failed to load stub (-308)!
Error: Algorithm run failed (-308)!
Warn : Last read operation left 414 bytes.
Error: Failed to run flasher stub (-308)!
Warn : Failed to get flash mappings (-308)!
jlink openocd error ?
Re: jlink openocd error ?
Hi
I am using Esp32 with Jlink and Jtag connection. I face the same error that you are getting every time i try to flash the esp using openocd in command prompt. Whats weird is for every 10 times i try to flash the code , randomly one time the code gets flashed successfully. I dont understand why its behaving like that.
Please let me know if you find any solution for this error.
Users browsing this forum: No registered users and 90 guests
