jlink openocd error ?
tabulous
Postby tabulous » Mon Nov 25, 2019 4:55 pm
Anyone know why this is happening ?
> Executing task: openocd -f interface/jlink.cfg -f board/esp-wroom-32.cfg <
Open On-Chip Debugger v0.10.0-esp32-20191114 (2019-11-14-14:19)
Licensed under GNU GPL v2
For bug reports, read
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 1000 kHz
Info : Configured 2 cores
Error: type 'esp32' is missing virt2phys
Info : J-Link EDU Mini V1 compiled Jul 10 2019 16:32:48
Info : Hardware version: 1.00
Info : VTarget = 3.206 V
Info : clock speed 1000 kHz
Info : esp32: Debug controller 0 was reset.
Info : esp32: Core 0 was reset.
tabulous
Re: jlink openocd error ?
Postby tabulous » Wed Nov 27, 2019 11:51 am
bump ???
Postby ESP_Sprite » Thu Nov 28, 2019 4:23 am
Not sure why it specifically gives you an error, but indeed, ESP32 doesn't really have virtual memory. Does it work otherwise? If so, you can ignore that line.
tabulous
Postby tabulous » Thu Nov 28, 2019 12:24 pm
This is all i get....
Info : J-Link EDU Mini V1 compiled Oct 22 2019 16:28:45
Info : VTarget = 3.212 V
Info : esp32: Debug controller 1 was reset.
Info : esp32: Core 1 was reset.
Postby ESP_Sprite » Fri Nov 29, 2019 2:30 am
Is there any program running on the ESP32? This smells like the watchdog timer keeps resetting it.
tabulous
Postby tabulous » Mon Dec 02, 2019 12:01 pm
surely the JTAG should stop the watchdog ?
dont know what is running as its a new device.
Device is the esp32-pico-d4
Postby ESP_Sprite » Tue Dec 03, 2019 2:14 am
Can you try uploading a known-good program via flash? Not sure if the WDT gets disabled this early in the process.
tabulous
Postby tabulous » Tue Dec 03, 2019 7:53 am
is there any way to clear the flash sections so just the bootlooader is there ?
thus if it was a wdg issue no apps would be running.
Postby ESP_Sprite » Wed Dec 04, 2019 2:36 am
No app being available is the problem, actually: the bootloader tries to load an app, sees none, then waits for the WDT to reset it. I *think* you can try to work around this by starting the ESP32 in download mode by pulling down GPIO0, but I'm not sure about that.
tabulous
Postby tabulous » Thu Dec 05, 2019 2:15 pm
So if i hold the boot switch whilst cycling EN switch i get
C:\Users\LTrueman>openocd -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Info : VTarget = 3.234 V
but what is this
Error: type 'esp32' is missing virt2phys ???
Users browsing this forum: Bing [Bot], Majestic-12 [Bot], ShreyAcharya and 87 guests
