jlink openocd error ?
Anyone know why this is happening ?
> Executing task: openocd -f interface/jlink.cfg -f board/esp-wroom-32.cfg <
Open On-Chip Debugger v0.10.0-esp32-20191114 (2019-11-14-14:19)
Licensed under GNU GPL v2
For bug reports, read
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 1000 kHz
Info : Configured 2 cores
Error: type 'esp32' is missing virt2phys
Info : J-Link EDU Mini V1 compiled Jul 10 2019 16:32:48
Info : Hardware version: 1.00
Info : VTarget = 3.206 V
Info : clock speed 1000 kHz
Info : esp32: Debug controller 0 was reset.
Info : esp32: Core 0 was reset.
Re: jlink openocd error ?
Not sure why it specifically gives you an error, but indeed, ESP32 doesn't really have virtual memory. Does it work otherwise? If so, you can ignore that line.
This is all i get....
Info : J-Link EDU Mini V1 compiled Oct 22 2019 16:28:45
Info : VTarget = 3.212 V
Info : esp32: Debug controller 1 was reset.
Info : esp32: Core 1 was reset.
Is there any program running on the ESP32? This smells like the watchdog timer keeps resetting it.
surely the JTAG should stop the watchdog ?
dont know what is running as its a new device.
Device is the esp32-pico-d4
Can you try uploading a known-good program via flash? Not sure if the WDT gets disabled this early in the process.
is there any way to clear the flash sections so just the bootlooader is there ?
thus if it was a wdg issue no apps would be running.
No app being available is the problem, actually: the bootloader tries to load an app, sees none, then waits for the WDT to reset it. I *think* you can try to work around this by starting the ESP32 in download mode by pulling down GPIO0, but I'm not sure about that.
So if i hold the boot switch whilst cycling EN switch i get
C:\Users\LTrueman>openocd -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Info : VTarget = 3.234 V
but what is this
Error: type 'esp32' is missing virt2phys ???
but what is this
Users browsing this forum: esp32New956832 and 42 guests
