Think I've found it.
I'm using arduino-esp32 (1.0.2). It lists:
set(COMPONENT_REQUIRES spi_flash mbedtls mdns ethernet)
Thanks, this is it. Will see about updating Arduino in master (still requires Ethernet), and also about whether this error message can give some clues about which component(s) require the missing one.william.ferguson.au wrote: ↑Wed Jul 24, 2019 12:35 pmBuild directory deleted and/or renamed.
I'm using arduino-esp32 (1.0.2). It lists:Code: Select all
get_filename_component(idf_project_name ${IDF_PROJECT_EXECUTABLE} NAME_WE)
set(app_bin "${CMAKE_BINARY_DIR}/${idf_project_name}.bin")
add_custom_command(OUTPUT /tmp/app.bin
DEPENDS "${app_bin}"
COMMAND "${CMAKE_COMMAND}" -E copy "${app_bin}" /tmp/app.bin
COMMENT "Copying ${app_bin} to /tmp/app.bin")
add_custom_target(copy_app_binary ALL DEPENDS /tmp/app.bin)
add_dependencies(copy_app_binary app)
idf_build_get_property(build_dir BUILD_DIR)
idf_build_get_property(elf_name EXECUTABLE_NAME GENERATOR_EXPRESSION)
set(app_bin "${build_dir}/${elf_name}.bin")
DEPENDS "${build_dir}/.bin_timestamp"
COMMENT "Copying binary to /tmp/app.bin")
add_dependencies(copy_app_binary gen_project_binary)
if(IDF_VERSION_MAJOR EQUAL 4)
# V4 logic
else()
# V3.x logic
endif()
Oops, sorry. Updated post to use the .bin file instead.william.ferguson.au wrote: ↑Fri Aug 02, 2019 9:33 pmThanks Angus, I can get the command to execute, but I still can't get the correct build output file.
${IDF_PROJECT_EXECUTABLE} resolves to "my-project.elf" but I need "my-project.bin"
Is there another variable that I can/should use?
It's mentioned here, but in the context of integrating with an existing CMake build system:william.ferguson.au wrote: ↑Fri Aug 02, 2019 9:33 pmWhere can I find a description/definition of variables like IDF_PROJECT_EXECUTABLE?
add_custom_command(
OUTPUT ${target_bin}
COMMAND "${CMAKE_COMMAND}" -E copy "${app_bin}" "${target_bin}"
# NB I couldn't get comment to work, so I used an extra COMMAND to echo the value
COMMAND ${CMAKE_COMMAND} -E echo "Copying ${app_bin} to ${target_bin}"
Just a note - that link is currently dead (404), yet linked from the current stable docs.ESP_Angus wrote: ↑Tue Aug 06, 2019 1:20 amIt's mentioned here, but in the context of integrating with an existing CMake build system:
https://docs.espressif.com/projects/esp ... e-projects
set(lib_name "lslibs_source")
set(lib_file "lib${lib_name}.a")
set(lib_path "${build_dir}/esp-idf/${lib_name}")
set(out_path "${build_dir}/../../my_esp32_application_project/lslibs_include/lib")
add_custom_command(OUTPUT ${out_path}/${lib_file}
DEPENDS "${lib_path}/${lib_file}"
COMMAND "${CMAKE_COMMAND}" -E copy "${lib_path}/${lib_file}" "${out_path}/${lib_file}"
COMMENT "Copying binary to ${out_path}/${lib_file}")
add_custom_target(copy_app_binary ALL DEPENDS ${out_path}/${lib_file})
Users browsing this forum: DrMickeyLauer and 82 guests
