On checking the above example code (esp-idf/examples/wifi/getting_started/station/main/station_example_main.c) for the current IDF 4.0 I wondered if a call to xEventGroupWaitBits is missing. The event group is created, connected bit is set in the handler, but where is the code waiting for the bits set / WiFi connection established?
I tried to extend this example a bit an promptly got an connection error because the WiFi connection was not established yet when a task tried to transfer data.
The similar code in esp-idf/examples/common_components/protocol_examples_common/connect.c has the xEventGroupWaitBits code BTW.
Or do I overlook something here?
Thomas
station_example_main.c: xEventGroupWaitBits missing?
Re: station_example_main.c: xEventGroupWaitBits missing?
Seems like you're correct. There should be an xEventGroupWaitBits() call at the end of app_main(). I'll open a ticket to fix this issue.
Users browsing this forum: Baidu [Spider] and 61 guests
