Canbus RX does not work
eowesi
Postby eowesi » Fri Nov 15, 2019 11:54 am
I simply connected the TX pin to the RX pin.(So there's no Can Transreceiver.) When I look through the oscilloscope, I can see the continuous data flow.That's why I think the TX pin works. Code is as below.
TaskHandle_t _xHandleTransmit;
void canbusTransmitTask(void *pvParam) {
    can_message_t message;
    message.identifier = 0xAAAA;
    message.flags = CAN_MSG_FLAG_EXTD;
    message.data_length_code = 4;
    for (int i = 0; i < 4; i++) {
        message.data[i] = 0;
    for (;;) {
        vTaskDelay(5000 / portTICK_PERIOD_MS);
        if (can_transmit(&message, pdMS_TO_TICKS(1000)) == ESP_OK) {
            printf("Message queued for transmission\n");
        } else {
            printf("Failed to queue message for transmission\n");
void app_main()
    //Initialize configuration structures using macro initializers
    can_general_config_t g_config = CAN_GENERAL_CONFIG_DEFAULT(GPIO_NUM_5, GPIO_NUM_4, CAN_MODE_NORMAL);
    can_timing_config_t t_config = CAN_TIMING_CONFIG_100KBITS();
    can_filter_config_t f_config = CAN_FILTER_CONFIG_ACCEPT_ALL();
    //Install CAN driver
    if (can_driver_install(&g_config, &t_config, &f_config) == ESP_OK) {
        printf("Driver installed\n");
    } else {
        printf("Failed to install driver\n");
        return;
    //Start CAN driver
    if (can_start() == ESP_OK) {
        printf("Driver started\n");
    } else {
        printf("Failed to start driver\n");
        return;
    xTaskCreate(canbusTransmitTask, "canbusTransmitTask", 1024, NULL, 4, &_xHandleTransmit);
    while ( 1 ) {
        //Wait for message to be received
        can_message_t message2;
        if (can_receive(&message2, pdMS_TO_TICKS(10000)) == ESP_OK) {
            printf("Message received\n");
        } else {
            printf("Failed to receive message2\n");
            continue;
        //Process received message2
        if (message2.flags & CAN_MSG_FLAG_EXTD) {
            printf("Message is in Extended Format\n");
        } else {
            printf("Message is in Standard Format\n");
        printf("ID is %d\n", message2.identifier);
        if (!(message2.flags & CAN_MSG_FLAG_RTR)) {
            for (int i = 0; i < message2.data_length_code; i++) {
                printf("Data byte %d = %d\n", i, message2.data[i]);
        vTaskDelay(50 / portTICK_PERIOD_MS);
Console output:
Driver installed
Driver started
I added the code below, but it still doesn't work. (after can_driver_install)
     gpio_set_pull_mode(4, GPIO_FLOATING);
     gpio_matrix_in(4, CAN_RX_IDX, false);
     gpio_pad_select_gpio(4);
     gpio_set_direction(4, GPIO_MODE_INPUT);
WiFive
Re: Canbus RX does not work
Postby WiFive » Fri Nov 15, 2019 12:16 pm
ESP_Dazz
Postby ESP_Dazz » Fri Nov 15, 2019 12:29 pm
can_general_config_t g_config = CAN_GENERAL_CONFIG_DEFAULT(GPIO_NUM_5, GPIO_NUM_4, CAN_MODE_NO_ACK);
message.flags = CAN_MSG_FLAG_EXTD | CAN_MSG_FLAG_SELF;
Documentation can be found here, and self test example can be found here.
Users browsing this forum: KaosESP32 and 188 guests
