Large ULP project build problem IDF V4.0 beta1
ginodecock
Postby ginodecock » Mon Nov 11, 2019 1:48 pm
I have a project that compiles fine under IDF V3.3.
When building under IDF V4.0 beta 1 I got the following error:
e/GitHub/esp-idf-v4.0-beta1/components/unity/include -IY:/VM/Share/GitHub/esp-idf-v4.0-beta1/components/ulp/cmake/-IY:/VM/Share/GitHub/esp-idf-v4.0-beta1/components/unity/unity/src -IY:/VM/Share/GitHub/esp-idf-v4.0-beta1/components/ulp/cmake/-IY:/VM/Share/GitHub/esp-idf-v4.0-beta1/components/wifi_provisioning/include -IY:/VM/Share/GitHub/esp-idf-v4.0-beta1/components/ulp/cmake/-IY:/VM/eclipse-workspace/tmp108logger/components/esp-si7021/include -o CMakeFiles/ulp_main.dir/sensor.ulp.S.obj -c sensor.ulp.S
sensor.ulp.S: Assembler messages:
sensor.ulp.S:230: Error: rel too far BFD_JUMPR_STEP
sensor.ulp.S:236: Error: rel too far BFD_JUMPR_STEP
sensor.ulp.S:251: Error: rel too far BFD_JUMPR_STEP
sensor.ulp.S:260: Error: rel too far BFD_JUMPR_STEP
sensor.ulp.S:271: Error: rel too far BFD_JUMPR_STEP
sensor.ulp.S:280: Error: rel too far BFD_JUMPR_STEP
sensor.ulp.S:293: Error: rel too far BFD_JUMPR_STEP
sensor.ulp.S:307: Error: rel too far BFD_JUMPR_STEP
[641/687] Building CXX object esp-idf/asio/CMakeFiles/__idf_asio.dir/asio/asio/src/asio.cpp.obj
ninja failed with exit code 1
Is there a way under IDF V4.0 to build ULP code using seperate assembler files?
WiFive
Re: Large ULP project build problem IDF V4.0 beta1
Postby WiFive » Mon Nov 11, 2019 11:04 pm
Are you using latest ulp toolchain?
ginodecock
Postby ginodecock » Tue Nov 12, 2019 5:32 pm
When using the cmake idf v4.0 the ulp toolchain is embedded.
If you have already set up ESP-IDF with CMake build system according to the Getting Started Guide, then the ULP toolchain is already installed.
Building using legacy GNU make build is older and works.
Any idea how to use multiple assembler files using CMake? That could also solve the problem.
WiFive
Postby WiFive » Wed Nov 13, 2019 1:58 am
message only exists in the old toolchain. It was removed here https://github.com/espressif/binutils-e ... 8bff1e18e1 Do you have an older version installed that may still be in PATH?
https://github.com/espressif/esp-iot-so ... xt#L17-L22
ginodecock
Postby ginodecock » Wed Nov 13, 2019 5:52 pm
Yes the esp32ulp toolchain was configured twice in PATH.
I builds now using CMake.
Users browsing this forum: No registered users and 62 guests
