Serial Modbus Master - restart stack
sabbay
Postby sabbay » Thu Oct 24, 2019 11:11 am
In my application modbus controller seems to start malfunctioning after some time (reads return error 0xffff), so I`m trying to restart the modbus stack, but the code below doesnt seem to work. Also I came across use after free bug while doing this https://github.com/espressif/esp-idf/issues/4238
How on earth should I restart this? Or is it unnecessary?
E (2968) MB_PORT_COMMON: xMBMasterPortTimersInit(121): timer set value failure, timer_isr_register() returned (0x105).
E (2968) MB_CONTROLLER_MASTER: mbc_serial_master_start(109): mb stack initialization failure, eMBInit() returns (0x3).
E (2978) MB_CONTROLLER_MASTER: mbc_master_start(211): SERIAL master start failure error=(0x103).
E (2988) MODBUS_CONTROLLER: modbus_init(114): mb controller start fail, returns(0x103).
E (2998) MODBUS_CONTROLLER: modbus_controller_loop(30): mb controller failed to restart
E (3008) FreeRTOS: FreeRTOS Task "modbus_gateway" should not return, Aborting now!
esp_err_t modbus_restart(void){
  SENSE_MB_CHECK((mbc_master_destroy() == ESP_OK), ESP_ERR_INVALID_STATE, "Failed to destroy mb handler structure.");
  return modbus_init();
esp_err_t modbus_init(void){
    mb_communication_info_t comm = {
            .port = MB_PORTNUM,
            .mode = MB_MODE_RTU,
            .baudrate = MB_BAUDRATE,
            .parity = MB_PARITY
    void* master_handler = NULL;
    esp_err_t err = mbc_master_init(MB_PORT_SERIAL_MASTER, &master_handler);
    SENSE_MB_CHECK((master_handler != NULL), ESP_ERR_INVALID_STATE,
                                "mb controller initialization fail.");
    SENSE_MB_CHECK((err == ESP_OK), ESP_ERR_INVALID_STATE,
                            "mb controller initialization fail, returns(0x%x).",
                            (uint32_t)err);
    err = mbc_master_setup((void*)&comm);
                            "mb controller setup fail, returns(0x%x).",
                            (uint32_t)err);
    err = mbc_master_start();
                            "mb controller start fail, returns(0x%x).",
                            (uint32_t)err);
    // Set UART pin numbers
    err = uart_set_pin(MB_PORTNUM, CONFIG_MB_UART_TXD, CONFIG_MB_UART_RXD,
                                    CONFIG_MB_UART_RTS, UART_PIN_NO_CHANGE);
            "mb serial set pin failure, uart_set_pin() returned (0x%x).", (uint32_t)err);
    // Set driver mode to Half Duplex
    err = uart_set_mode(MB_PORTNUM, UART_MODE_RS485_HALF_DUPLEX);
            "mb serial set mode failure, uart_set_mode() returned (0x%x).", (uint32_t)err);
    return err;
Environment
esp-idf: v4.1-dev-437-gd2ad0f077
xtensa-esp32-elf-gcc (crosstool-NG esp32-2019r1) 8.2.0
Linux
esp-wroom-32 devkitv1
mronchi
Re: Serial Modbus Master - restart stack
Postby mronchi » Fri Oct 25, 2019 3:34 am
I'm facing exactly the same issue, after a while where it works ok, start to received 0xFFFF error, and if I try to re-initialize Modbus after use mbc_master_destroy(), I'm get the Heap error and reboot.
EDIT:
After check alisitsyn answers on https://github.com/espressif/esp-idf/issues/4238 seems to be fixed.
Best regards.
juanchu98
Postby juanchu98 » Mon Oct 19, 2020 6:51 am
Hello everyone,
I'm facing this same issue in a recent release of ESP-IDF (v4.3-dev-907-g6c17e3a64).
Could you please tell me how did you fix the issue?
I have checked all the issues on github but seems i cannot reinit the Modbus Stack. I still get the errors similar to @mronchi:
Any update on this?
Thanks!!
ESP_alisitsyn
Contact:
Postby ESP_alisitsyn » Tue Oct 20, 2020 4:09 pm
Hello @juanchu98,
0x105 = ESP_ERR_NOT_FOUND.
The Modbus stack uses the timer group to measure timeouts. THis looks like the default timer group is already used in your application that causes this error. Please try to configure the timer group in freemodbus kconfig menu (CONFIG_FMB_TIMER_GROUP, CONFIG_FMB_TIMER_INDEX).
Users browsing this forum: Bing [Bot] and 88 guests
