SPIFFS file read failure in webserver
techno500
Postby techno500 » Wed Oct 02, 2019 6:42 pm
Code is from a "GET" request that lists SPIFFS files as download able links; read by readFile function. first pass downlowloaded file is good; all attempts fail, after first download:
               // Check the action to see if it was a GET request.
                         else if (strcmp(path, "/SdBrowse") == 0)   // Respond with the path that was accessed.
                              // send a standard http response header
                              client.println("HTTP/1.1 200 OK");
                              client.println("Content-Type: text/html");
                              client.println();
                              client.println("<!DOCTYPE HTML>");
                              client.println("<html>");
                              client.println("<head><title>SDBrowse</title>");
                              // print all the files, use a helper to keep it clean
                              client.println("<h2>Collected Observations</head></h2>");
                              client.println("<body><h3><br>");
                              String str = String("<!DOCTYPE HTML><html><head></head>");
                              if (!SPIFFS.begin(true))
                                   Serial.println("An Error has occurred while mounting SPIFFS");
                                   return;
                              File root = SPIFFS.open("/");
                              File file = root.openNextFile();
                              while (file)
                                   if(strncmp(file.name(), "/LOG", 4) == 0)
                                        str += "<a href=\"";
                                        str += file.name();
                                        str += "\">";
                                        str += file.name();
                                        str += "</a>";
                                        str += "    ";
                                        str += file.size();
                                        str += "<br>\r\n";
                              client.print(str);
                              client.println("</h3><br><br>");
                              client.println("<a href=http://" + publicIP + ":" +  LISTEN_PORT + "/Weather    >Home</a><br>");
                              client.println("</body>");
                              client.println("</html>");
                              end();
Problem occurs when "SdBrowse" web page remains open and a after 1st download, a second file is selected. Second file does not download. I have inserted numeric values to check Sketch flow; it appears to complete properly, just no file download.
Serial monitor output showing Sketch flow in readFile function:
Client connected: Wed , 10/02/2019 , 01:26:45 EDT
Client IP: 10.0.0.146
Processing request
Action: GET
Path: /SdBrowse
Client closed: Wed , 10/02/2019 , 01:26:46 EDT
Client connected: Wed , 10/02/2019 , 01:26:48 EDT
Processing request
Action: GET
Path: /LOG02102019.TXT
File55: /LOG02102019.TXT
57
59
60
61
Client closed: Wed , 10/02/2019 , 01:26:48 EDT
Client connected: Wed , 10/02/2019 , 01:26:56 EDT
Processing request
Action: GET
Path: /LOG01102019.TXT
File55: /LOG01102019.TXT
57
59
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
60
61
Client closed: Wed , 10/02/2019 , 01:26:56 EDT
Function readFile:
void readFile()
     if(!SPIFFS.begin(true))
        return;
     //     digitalWrite(online, HIGH);   //turn-on online LED indicator
     String filename = (const char *)&MyBuffer;
     Serial.print("File55:  ");
     Serial.println(filename);
     File webFile = SPIFFS.open(filename);
     Serial.println("57");
     if (!webFile)
          Serial.println("File58 LOG file failed to open");
          Serial.println("\n");
     else
          Serial.println("59");
          char buf[1024];
          int len;
          while  (len = webFile.read((uint8_t *)buf, 1024))
               Serial.println("60");
               client.write((const char*)buf, len);
               Serial.println("61");
          webFile.flush();
          webFile.close();
     error = 0;
     delayTime = 1000;
     MyBuffer[0] = '\0';
//     digitalWrite(online, LOW);   //turn-off online LED indicator
How do I enable downloading of second file; while web page remains open. Why is this issue happening? How do I fix code?
ESP32 Web site for project: http://bit.ly/2lcu0NX
William
Users browsing this forum: No registered users and 65 guests
