ESP32 WROVER-B, Arduino IDE compatibility
I have my custom PCB designed for ESP32 WROVER, recently i damaged my module and ordered ESP32 WROVER-B module as replacement. After soldering it on the PCB I cannot connect to the module via Arduino IDE. My question is, is -B module not supported by Arduino IDE or should I check my connections again ?
Re: ESP32 WROVER-B, Arduino IDE compatibility
ESP32 WROVER-B is compatible with Arduino IDE. The manufacturers ship it with Arduino support stored inside ROM. You might be have connection issues. You should verify.
does your board support manual or automatic bootloader configuration?
Designed it for automatic bootloader, but I included, reset and GPIO0 tact switch in case I made some mistakes in the circuit. I am trying to connect manually for now with only TX and RX connected to TTL converter.
Try this approach and let me know.
Users browsing this forum: No registered users and 82 guests
