VSPI, HSPI and SDMMC together.
Salakhov
Postby Salakhov » Sat Aug 24, 2019 2:49 pm
I make some POV project.
Both VSPI and HSPI are used for 2 led strips control. SPI speed is maximal of possible one. It is 80MHz.
Folowing default pins used:
vspi
SCLK = 18, MISO = 19, MOSI = 23, SS = 5
hspi
SCLK = 14, MISO = 12, MOSI = 13, SS = 15
SD card is connected to pins: 27, 21, 4, 22.
There is no problem to read and to show pictures.
But I want to read some video and to show it on POV.
I want use SDMMC library and connections:
D2 12
D3 13
CMD 15
CLK 14
D0 2
D1 4.
Because of it I have to change hspi pins to alternative recommended:
SCLK=25, MISO=26, MOSI=27, SS=32.
vspi will be the past:
SCLK = 18, MISO = 19, MOSI = 23, SS = 5.
The question:
Is it possible to use hspi, vspi and SD_MMC together?
Will speed is left the same?
Thanks!
Re: VSPI, HSPI and SDMMC together.
Postby ESP_Sprite » Mon Aug 26, 2019 3:52 am
No, sorry. If you route SPI signals over the GPIO matrix, speeds are limited to 40MHz. (Ref here)
Salakhov
Postby Salakhov » Mon Aug 26, 2019 8:34 am
Thank you very much for the reply.
What about speed of SDMMC and vspi if I shall not use hspi?
SDMMC
D2 12
D3 13
CMD 15
CLK 14
D0 2
D1 4.
vspi
P.S. Where to find description of SDMMC library? I have found only examples.
Thanks!
Postby ESP_Sprite » Mon Aug 26, 2019 10:10 am
In general, if you use the dedicated pins of the SPI peripheral, you'll be able to get 80MHz. If you do not, you're limited to 40MHz (plus some extra requirements, see the link I posted earlier.) SDMMC documentation would be here.
Users browsing this forum: No registered users and 64 guests
