RTC_DATA_ATTR and struct
hellraise007
Postby hellraise007 » Thu Aug 22, 2019 9:18 am
Is it possible to store data under struct like the one below in RTC memory so I can retain the values of all the objects on wake up
struct Button {
  const uint8_t PIN;
  volatile uint32_t numberKeyPresses;
  volatile bool pressed;
Re: RTC_DATA_ATTR and struct
Postby ESP_Sprite » Fri Aug 23, 2019 1:55 am
Yes.
hellraise007
Postby hellraise007 » Fri Aug 23, 2019 10:26 am
Yes.
Thanks for the reply. What is the correct syntax for this. This is illegal
RTC_DATA_ATTR struct Button {
  const uint8_t PIN;
struct Button {
  RTC_DATA_ATTR const uint8_t PIN;
  RTC_DATA_ATTR volatile uint32_t numberKeyPresses;
  RTC_DATA_ATTR volatile bool pressed;
I am not quite familiar with attributes.
Postby ESP_Sprite » Mon Aug 26, 2019 3:56 am
Do it where you actually allocate memory for your data. Something like this (untested):
struct Button {
  const uint8_t PIN;
RTC_DATA_ATTR  struct Button my_button;
Users browsing this forum: No registered users and 59 guests
