MSYS2 is slow on Windows 10
Re: MSYS2 is slow on Windows 10
Now I tried to install the same build system (CMake based) on a Windows 7 PC (previous installation was on Windows 10) and I am encountering compile time errors. I think I will open a separate thread for this.
"Whoever believes to be someone has stopped becoming someone"
Sokrates
Sokrates
Yes, this looks equivalent.squonk11 wrote: ↑Thu Jan 03, 2019 6:46 pm@ESP_Angus
My output is:Python in this case is the standard Windows Python 2.7 install. Can you compare with the output you see from idf.py?Code: Select all
Executing "C:\Python27\python.exe C:\Users\gus\dev\esp-idf\tools/idf_monitor.py -p COM6 -b 115200 C:\Users\gus\Desktop\esp-idf-v3.1.2\examples\get-started\hello_world\build\hello-world.elf -m 'C:\Python27\python.exe' 'C:\Users\gus\Desktop\esp-idf-v3.1.2\tools\idf.py' '-p' 'COM6'"... --- idf_monitor on COM6 115200 ---
That looks quite similar to yours, right?Code: Select all
Executing "C:\Python27\python.exe C:\Users\xxxx\esp\esp-idf\tools/idf_monitor.py -p COM11 -b 115200 C:\Users\xxxx\esp\hello_world\build\hello-world.elf -m 'C:\Python27\python.exe' 'C:\Users\xxxx\esp\esp-idf\tools\idf.py' '-p' 'COM11'"...
What language and keyboard layout do you have set?
Both German.
Maybe that is the problem? How can I switch to English - just for test?
Sokrates
Sokrates
Hello All,
Issue has been resolved for windows 10 system or still remains? Because we are also facing same issue at our end while using MSYS2 into windows 10 system with ESP32 IDF.
Let me know if any permanent solution for same.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hello Ritesh,
since I switched to the CMake build system under native Windows I did not try MSYS2 again - so I don't know if this problem has been taken care of. In general: if you want to work with ESP32 and esp-idf I recommend to use cmake since this will be the new build system from Espressif; make will no longer be supported in future.
Kind regards
Lothar
Kind regards
Lothar
Sokrates
Sokrates
But the cmake setup is not available for stable idf 3.2.2 right ?
It is available, as a preview: https://docs.espressif.com/projects/esp ... index.htmlvinodstanur wrote: ↑Sun Jul 21, 2019 12:10 pmBut the cmake setup is not available for stable idf 3.2.2 right ?
Regarding the problem under MSYS2, did you find that changing any keyboard layout settings causes the problem to go away?
Hello,squonk11 wrote: ↑Sun Jul 21, 2019 11:41 amHello Ritesh,
Kind regards
Lothar
We haven't moved into CMAKE and we don't have any planning to move into that because there are already few products are about to launch in which we have used older IDF.
I agree that they have ported IDF on CMAKE to resolve that kind of issue.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hello,ESP_Angus wrote: ↑Mon Jul 22, 2019 3:02 amIt is available, as a preview: https://docs.espressif.com/projects/esp ... index.htmlvinodstanur wrote: ↑Sun Jul 21, 2019 12:10 pmBut the cmake setup is not available for stable idf 3.2.2 right ?
I don't think that changing Keyboard Layout settings will resolve this issue because issue is something different which can be traced using make -d option as well.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi Ritesh,
Sorry, I think I got confused on account of several different issues being discussed in this thread. If your issue is MSYS2 being slow, please reply here with as many details as you can find and maybe there are some improvements we can suggest.
If the issue is something else, please open a new thread with the details.
Users browsing this forum: Google [Bot], petterk and 64 guests
