I am using wroom-32D and eclipse for flashing. I managed to get the a2dp sink example working with I2S_MODE_DAC_BUILT_IN.
I changed only the bt_app_a2d_data_cb function in bt_app_av.c as suggested in this forum:
uint16_t buffer[2048];
void bt_app_a2d_data_cb(const uint8_t *data, uint32_t len)
size_t bytes_written;
for(int i = 0; i < 2048; i++){
buffer[i] = ((int16_t*)data)[i] + 0x8000;
i2s_write(0, (const uint8_t*) buffer, len, &bytes_written, portMAX_DELAY);
if (++s_pkt_cnt % 100 == 0) {
ESP_LOGI(BT_AV_TAG, "Audio packet count %u", s_pkt_cnt);
volume_set_by_local_host
#define MUL_16S_16S(_x, _y) ((_x) * (_y))
#define MUL_16S_16S(_x, _y) ((_x)*4 * (_y))
My extremely old oscilloscope gives the following when no audio is playing with gpio 26 channel inverted, so it is pretty much identical with gpio 25. Gpio 26 has a 1 uF capacitor in series : And when playing: Is this normal? Why the positive voltage peak is cut off? How could i make the volume louder? How could I eliminate the random cliches that hear every 10s or so....?
Also additional question, I have seen examples where the deprecated i2s_push_sample() has been used with separate data[2] for left and right channels. How is i2s_write() handling the stereo issue?
Thanks for any help!
My sdkconfig.default
CONFIG_BT_ENABLED=y
CONFIG_BTDM_CTRL_MODE_BLE_ONLY=
CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY=y
CONFIG_BTDM_CTRL_MODE_BTDM=
CONFIG_BT_BLUEDROID_ENABLED=y
CONFIG_BT_CLASSIC_ENABLED=y
CONFIG_BT_A2DP_ENABLE=y
CONFIG_BT_SPP_ENABLED=n
CONFIG_BT_GATTS_ENABLE=n
CONFIG_BT_GATTC_ENABLE=n
CONFIG_BT_BLE_SMP_ENABLE=n
