[SOLVED]Load spiffs_image.img after OTA
Ritesh
Contact:
Re: Load spiffs_image.img after OTA
Postby Ritesh » Wed Jul 10, 2019 4:52 pm
elie_daan wrote:
Wed Jul 10, 2019 9:25 am
Thanks you Ritesh for your help. Finally I resolved the problem. It was always writing at the beginning of the partition. I had to implement a offset because my buffer was 1Kb.
int offset=0;
    /*deal with all receive packet*/
    while (1) {
        int data_read = esp_http_client_read(client, ota_write_data, BUFFSIZE);
        if (data_read < 0) {
            ESP_LOGE(TAG, "Error: SSL data read error");
            http_cleanup(client);
            task_fatal_error();
        } else if (data_read > 0) {
            /* 3 : WRITE SPIFFS PARTITION */
            err= esp_partition_write(spiffs_partition,offset,(const void *)ota_write_data, data_read);
            if (err != ESP_OK) {
                task_fatal_error();
            offset=offset+1024;
Great work. Thanks again for your effort to resolve that issue.
Regards,
Ritesh Prajapati
WiFive
Re: [SOLVED]Load spiffs_image.img after OTA
Postby WiFive » Wed Jul 10, 2019 5:14 pm
You write length data_read
So
offset += data_read
pedros89
Postby pedros89 » Tue Aug 03, 2021 9:37 am
Thank you for this post. I needed to update SPIFFS from OTA and I managed to do it thanks to you.
You may find the code for Arduino IDE below. I took most of code form this post to make it.
https://github.com/pedros89/ESP32-OTA-u ... th-Arduino
For me it works great. Bye!
Ritesh
Contact:
Postby Ritesh » Sat Aug 28, 2021 10:36 am
Great. Thanks for putting details with link which can be helpful for others as well
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 117 guests
