Error when compiling with xtensa-esp32-elf
When I compile the example without modifying anything, I got this error:
/home/fgh/esp/xtensa-esp32-elf/xtensa-esp32-elf/sys-include/stdlib.h:155:44: error: expected initializer before '__result_use_check'
void *reallocarray(void *, size_t, size_t) __result_use_check __alloc_size(2)
/home/fgh/esp/xtensa-esp32-elf/xtensa-esp32-elf/sys-include/stdlib.h:340:52: error: expected initializer before '__alloc_align'
void * aligned_alloc(size_t, size_t) __malloc_like __alloc_align(1)
It's so confusing...
Re: Error when compiling with xtensa-esp32-elf
Hi fgh1999,
We need some details to try and tell what the problem is. Can you please share your host OS, ESP-IDF version, the full command line you are running and all of the build output (not just the error lines). Plus any other details which may be relevant.
Thanks,
Angus
Thanks,
Angus
OS: Ubuntu 18.04 LTS
fgh@ubuntu:~/esp/esp-mdf/examples/function_demo/mwifi/no_router$ make
Toolchain path: /home/fgh/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
WARNING: Toolchain version is not supported: esp32-2019r1
Expected to see version: crosstool-ng-1.22.0-80-g6c4433a
Please check ESP-IDF setup instructions and update the toolchain, or proceed at your own risk.
WARNING: Compiler version is not supported: 8.2.0
Expected to see version(s): 5.2.0
Python requirements from /home/fgh/esp/esp-mdf/esp-idf/requirements.txt are satisfied.
CXX build/asio/asio/asio/src/asio.o
In file included from /home/fgh/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/cstdlib:75,
from /home/fgh/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/ext/string_conversions.h:41,
from /home/fgh/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/bits/basic_string.h:6391,
from /home/fgh/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/8.2.0/string:52,
from /home/fgh/esp/esp-mdf/esp-idf/components/asio/asio/asio/include/asio/impl/error.ipp:19,
from /home/fgh/esp/esp-mdf/esp-idf/components/asio/asio/asio/include/asio/impl/src.hpp:22,
from /home/fgh/esp/esp-mdf/esp-idf/components/asio/asio/asio/src/asio.cpp:11:
/home/fgh/esp/esp-mdf/esp-idf/make/component_wrapper.mk:285: recipe for target 'asio/asio/src/asio.o' failed
make[1]: *** [asio/asio/src/asio.o] Error 1
/home/fgh/esp/esp-mdf/esp-idf/make/project.mk:530: recipe for target 'component-asio-build' failed
make: *** [component-asio-build] Error 2
It gave warnings but it seems that I can do nothing because I don't know where to download the toolchain with given version...
Thanks for the extra details. I see from the log output you're using ESP-MDF.
Current version of ESP-MDF is based on ESP-IDF V3.2, so you'll need to follow the V3.2 setup guide here:
https://docs.espressif.com/projects/esp-idf/en/v3.2.2/
This version of the guide has the download links for the correct version of the toolchain.
Thank you for your help but it still dose not fully work...
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a
Compiler version: 5.2.0
CC build/main/no_router_example.o
/home/fgh/esp/esp-mdf/examples/function_demo/mwifi/no_router/main/no_router_example.c:25:24: fatal error: mdf_common.h: No such file or directory
compilation terminated.
/home/fgh/esp/esp-mdf/esp-idf/make/component_wrapper.mk:285: recipe for target 'no_router_example.o' failed
make[1]: *** [no_router_example.o] Error 1
/home/fgh/esp/esp-mdf/esp-idf/make/project.mk:530: recipe for target 'component-main-build' failed
make: *** [component-main-build] Error 2
I'm having this problem as well, following update to ESP-IDF (master branch), and upgrade of the compiler. I read This github issue: https://github.com/micropython/micropython/issues/4850.
Do I really need to downgrade crosstool-ng to 1.22? That's harsh, if so. Any advice?
- $ ct-ng
- This is crosstool-NG version 1.24.0
- $ xtensa-esp32-elf-gcc -v
- Using built-in specs.
- COLLECT_GCC=xtensa-esp32-elf-gcc
- COLLECT_LTO_WRAPPER=/opt/esp/xtensa-esp32-elf/bin/../libexec/gcc/xtensa-esp32-elf/8.2.0/lto-wrapper
- Target: xtensa-esp32-elf
- Configured with: /builds/idf/crosstool-NG/.build/xtensa-esp32-elf/src/gcc/configure --build=x86_64-build_pc-linux-gnu --host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf --prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf --with-local-prefix=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf --with-headers=/builds/idf/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/include --with-newlib --enable-threads=no --disable-shared --with-pkgversion='crosstool-NG esp32-2019r1' --disable-__cxa_atexit --enable-cxx-flags='-fno-rtti -ffunction-sections' --disable-libgomp --disable-libmudflap --disable-libmpx --disable-libssp --disable-libquadmath --disable-libquadmath-support --with-gmp=/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-mpfr=/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-mpc=/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-isl=/builds/idf/crosstool-NG/.build/xtensa-esp32-elf/buildtools --enable-lto --enable-target-optspace --without-long-double-128 --disable-nls --enable-multiarch --enable-languages=c,c++ --disable-libstdcxx-verbose --enable-threads=posix --enable-gcov-custom-rtio --enable-libstdcxx-time=yes
- Thread model: posix
- gcc version 8.2.0 (crosstool-NG esp32-2019r1)
You don't need to use crosstool-ng at all unless you want to build your own toolchain, but you will need to install an earlier toolchain version (gcc 5.2.0) that was built with crosstool-ng 1.22.
You can find this by following the Getting Started guide for the current stable release (v3.2.2):
https://docs.espressif.com/projects/esp-idf/en/stable/
ESP_Angus, thanks for your help but following your instructions causes this output (which is why I upgraded to 8.2 in the first place).
It builds. But not without lots of noise and disclaimer. Any idea how to rectify this?
$ make
Toolchain path: /opt/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
WARNING: Toolchain version is not supported: crosstool-ng-1.22.0-80-g6c4433a
Expected to see version: esp32-2019r1
WARNING: Compiler version is not supported: 5.2.0
Expected to see version(s): 8.2.0
Python requirements from /opt/esp/requirements.txt are satisfied.
What version of IDF do you have and how did you get the IDF code (via Micropython or a standalone git clone or some other method)?
If you're using ESP-IDF master branch (v4.0-dev), then you will need gcc 8.2.0 for this. For earlier ESP-IDF versions (v3.x, such as the version shipped with MicroPython) then you will need gcc 5.2.0.
Stand-alone git request. Pulled fresh last night. By your hypothesis, I'm on 4.0. I will revert to latest 3.x and report back. Thanks again, ESP_Angus.
$ git log
commit fdab15dc76a3464ed10ce03e9b9cf1a5cd2aa0d1 (HEAD -> master, origin/master, origin/HEAD)
Merge: 6ae352c3a 8f2d13d9d
Author: Jiang Jiang Jian <jack@espressif.com>
Date: Mon Jul 15 12:41:59 2019 +0800
Merge branch 'bugfix/modify_wifi_country_struct' into 'master'
esp32: make wifi_country_t in idf consistent with VNC
See merge request espressif/esp-idf!5463
Users browsing this forum: No registered users and 225 guests
