unable to install packages on msys
Sunil Dullolli
Postby Sunil Dullolli » Wed Jul 03, 2019 6:00 pm
Hello all,
I downloaded the readily available msys2 & toolchain packages from https://docs.espressif.com/projects/esp ... hain-setup. I see that I will also need cmake to be installed as I am using a third party component which uses cmake. When I do "pacman -S mingw-w64-i686-cmake" or for that matter any other installations doesn't work. It stops at "Retrieving packages" and when I run it again it creates "db.lck" file and even deleting that file is not helping out. i.e. it is unable to lock
database for some reason.
Is there a workaround to get through this? Any help is appreciated.
ESP_Roland
Re: unable to install packages on msys
Postby ESP_Roland » Thu Jul 04, 2019 8:03 am
Hi Sunil Dullolli.
Since you are using the "latest" branch, starting right now and will already need cmake then I would recommend you to use instead our cmake-based toolchain (https://docs.espressif.com/projects/esp ... index.html) which will be the default one in the upcoming release.
I'm not sure about the described problem with MSys. Maybe you could try to download it once again.
Rene9M
Postby Rene9M » Thu Jul 04, 2019 11:10 am
The problem isn't with the download of the tool itself, but with the packages using mingw-get Mobdro.
Sunil Dullolli
Postby Sunil Dullolli » Fri Jul 12, 2019 7:15 pm
Thank you for your suggestions.
Users browsing this forum: axellin, Bing [Bot], Google [Bot] and 63 guests
