How to handle Git submodules in forks?
niflizn
Postby niflizn » Sun Jun 30, 2019 11:01 pm
Commit #008ad9a on esp-idf replaced the https***github.com/espressif/esp-idf/... URLs in .gitmodules with relative links.
The switch to relative URLs for submodules has broken our fork, because they reference our repo, which does not contain mirrors of the upstream source.
I suppose I could make my own forks of all the required submodules manually, but that is a rather tedious task.
Further, how will we make sure that we have the intended versions.
What is the recommended workflow?
WiFive
Re: How to handle Git submodules in forks?
Postby WiFive » Mon Jul 01, 2019 1:29 am
Yes this is annoying because you can't click on a submodule to browse the source based on that commit on GitHub now either.
Did you try
git config submodule.SubModuleName.url github_url
I don't think git has a way to specify a default url in case the relative url is not valid, unfortunately.
ESP_Angus
Postby ESP_Angus » Mon Jul 01, 2019 3:50 am
Hi Nifomorph,
Thanks for bringing this up.
You can use "git config" to rewrite the URLs as WiFive suggests, then re-update submodules. Or if you're starting from scratch then you can clone the upstream repository and then switch over, as follows:
git clone --recursive https://github.com/espressif/esp-idf.gt
git remote set-url origin <idf fork>
git fetch origin <branch>
git checkout <branch>
Another option would be to add a commit on the fork that rewrites the .gitmodules file. Although this will need updating when new submodules are added upstream.
We're going to add a script to the repo that rewrites all of the URLs to github ones. Once that's available it will be the recommended approach after cloning the base repo.
Ah, that is annoying. Maybe it's possible to bring it up as a request with GitHub somehow.
Unfortunately, although this approach is annoying in some ways it has also solved some long-standing problems we've had with our own development and continuous integration processes. GitHub does not always work reliably in China, so we keep internal forks of everything ourselves. Gitlab CI (which we use for our CI) has some restrictions around using any custom scripts as part of "git clone", it causes awkwardness with establishing a "clean" working directory. So we were regularly finding strange things happening in our "clean" CI clones.
That said: We don't want to tidy up our own process while breaking our users' processes, so we'll add support for setting the correct submodule paths in forks ASAP.
niflizn
Postby niflizn » Mon Jul 01, 2019 12:52 pm
Thanks for the quick reply.
We will try to work around the issue by rewriting the .gitmodules file for now.
It might be nice to have a $SUBMODULE_BASE_URL variable or similar mechanism to point to a common repo for modules referred using relative paths, but I don't know what would be involved in this.
Alternatively, have a GitHub feature to make forks of submodules when forking a repo.
Regarding the issue with clickable submodule links, a request for that has already been opened on GitHub about a month ago:
https://github.community/t5/How-to-use- ... 4650#M7066
You might want to give that request an upvote ;)
niflizn
Postby niflizn » Mon Jul 01, 2019 4:39 pm
I ended up rewriting .gitmodules with relative paths, but replaced URLs pointing to an Espressif repo in the following style:
[submodule "components/bt/controller/lib"]
	path = components/bt/controller/lib
	url = ../esp32-bt-lib.git
To:
	url = ../../espressif/esp32-bt-lib.git
Please consider if this could work for you and maybe modify the 'master' branch accordingly.
I added a PR for this here:
https://github.com/espressif/esp-idf/pull/3721
Users browsing this forum: No registered users and 117 guests
