Esp32 changing pwm frequency
lucian_v
Postby lucian_v » Wed Jun 05, 2019 6:37 am
I am using this code to vary duty cycle of pwm and is working fine
// the number of the LED pin
const int ledPin = 16;  // 16 corresponds to GPIO16
// setting PWM properties
const int freq = 5000;
const int ledChannel = 0;
const int resolution = 8;
void setup(){
  // configure LED PWM functionalitites
  ledcSetup(ledChannel, freq, resolution);
  // attach the channel to the GPIO to be controlled
  ledcAttachPin(ledPin, ledChannel);
void loop(){
  // increase the LED brightness
  for(int dutyCycle = 0; dutyCycle <= 255; dutyCycle++){
    // changing the LED brightness with PWM
    ledcWrite(ledChannel, dutyCycle);
    delay(15);
  // decrease the LED brightness
  for(int dutyCycle = 255; dutyCycle >= 0; dutyCycle--){
    delay(15);
But I want vary frequency and keep duty cycle constant, My issue is that if I use
ledcWriteTone(channel, frequency);
is not working...I mean if I use with a bigger delay like 1000 is changing frequency but I want do this very fast.
Is there other option to achieve this?
Basically I need change up to 60Hz starting from minimum possible...
Thank you in adavance
Re: Esp32 changing pwm frequency
Postby ESP_Sprite » Wed Jun 05, 2019 7:20 am
Move: ADF -> ESP-IDF
Users browsing this forum: owenjames and 129 guests
