I'm making consecutive calls to one device using polling transactions. I have acquired the bus in initialization. My transactions are relatively short and usually come in chunks of 10 (10 polling transactions).
I find that the speed is still not satisfactory. How can I improve this?
SPI very slow
Re: SPI very slow
Specifically, by logging a time value I'm reading that each polling transaction takes around 3 ms. Should it not be much quicker? <100 us?
Re: SPI very slow
Hi jollytopper,
What's your clock speed?
Can you provide a piece of simple code for us to test it? From our internal test, one-byte transaction should only take 8us (at 10MHz).
Re: SPI very slow
I have found that the problem was I was outputting many ESP_LOG statements over UART, thus causing delay.
Re: SPI very slow
Re: SPI very slow
So, After reducing logs dis you get improvement into SPI Speed?
Regards,
Ritesh Prajapati
Ritesh Prajapati
Re: SPI very slow
Yes. Speed improved significantly after removing log statements.
Re: SPI very slow
Great. Thanks for update regarding same.jollytopper wrote: ↑Mon Jun 03, 2019 1:56 amYes. Speed improved significantly after removing log statements.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Bing [Bot], Google [Bot] and 121 guests
