Hello Everyone,
I'm getting in logs that "root not fixed" error, even though i have given correct SSID and PASSWORD.
here is the log example.
thanks..
I (256) wifi: wifi driver task: 3ffc3488, prio:23, stack:3584, core=0
I (256) wifi: wifi firmware version: 3f769b9
I (256) wifi: config NVS flash: enabled
I (266) wifi: config nano formating: disabled
[0;32mI (266) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
[0;32mI (276) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
I (306) wifi: Init dynamic tx buffer num: 32
I (306) wifi: Init data frame dynamic rx buffer num: 32
I (306) wifi: Init management frame dynamic rx buffer num: 32
I (316) wifi: Init static rx buffer size: 1600
I (316) wifi: Init static rx buffer num: 10
I (316) wifi: Init dynamic rx buffer num: 32
[0;32mI (386) phy: phy_version: 4000, b6198fa, Sep 3 2018, 15:11:06, 0, 0[0m
I (386) wifi: mode : sta (b4:e6:2d:d5:b6:ed) + softAP (b4:e6:2d:d5:b6:ee)
I (386) wifi: Init max length of beacon: 752/752
I (396) wifi: Init max length of beacon: 752/752
W (396) wifi: [beacon]new interval:100ms
I (406) mesh: <nvs>read layer:0
I (426) mesh: <nvs>read assoc:0
I (1416) wifi: Set ps type: 0
[0;32mI (1416) mesh_main: <MESH_EVENT_STARTED>ID:77:77:77:77:77:77[0m
[0;32mI (1416) mesh_main: mesh starts successfully, heap:177312, root not fixed
[0m
I (1716) mesh: [SCAN][ch:1]AP:6, otherID:0, MAP:0, idle:0, candidate:1, root:0, topMAP:0[c:0,i:0]router found<>
I (1716) mesh: 1232[SCAN]init rc[b4:e6:2d:d5:b6:ee,-31], mine:0, voter:0
I (1726) mesh: 1270, vote myself, router rssi:-31 > voted rc_rssi:-120
I (1726) mesh: [SCAN:1/10]rc[128][b4:e6:2d:d5:b6:ee,-31], self[b4:e6:2d:d5:b6:ed,-31,reason:0,votes:1,idle][mine:1,voter:1(1.00)percent:1.00][128,1,b4:e6:2d:d5:b6:ee]
W (5606) wifi: [beacon]interval:100ms
I (5616) mesh: [DONE]connect to router:AndroidAP, rssi:-32, 10:07:b6:ac:a1:5d[layer:0, assoc:0], my_vote_num:1/voter_num:1, rc[b4:e6:2d:d5:b6:ee/-32]
I (14056) wifi: n:1 1, o:1 0, ap:1 1, sta:1 0, prof:1
I (15036) wifi: state: init -> auth (b0)
I (15046) wifi: state: auth -> assoc (0)
I (15056) wifi: state: assoc -> run (10)
I (15076) wifi: connected with AndroidAP, channel 1
I (15076) wifi: pm start, type: 0
I (15076) mesh: [scan]new scanning time:600ms
W (15076) wifi: [beacon]new interval:300ms
[0;31mE (15076) event: invalid static ip[0m
[0;33mW (15086) mesh_main: <MESH_EVENT_ROUTING_TABLE_REMOVE>remove 1, new:1[0m
[0;32mI (15086) mesh_main: <MESH_EVENT_PARENT_CONNECTED>layer:0-->1, parent:10:07:b6:ac:a1:5d<ROOT>, ID:77:77:77:77:77:77[0m
I (15096) mesh: <nvs>write layer:1
[0;32mI (15106) mesh_main: <MESH_EVENT_ROOT_ADDRESS>root address:b4:e6:2d:d5:b6:ee[0m
[0;33mW (15106) mesh_main: [#RX:1/1][L:1] parent:10:07:b6:ac:a1:5d, receive from b4:e6:2d:d5:b6:ed, size:1460, heap:175676, flag:0[err:0x0, proto:0, tos:0][0m
[0;33mW (16106) mesh_main: [#RX:2/2][L:1] parent:10:07:b6:ac:a1:5d, receive from b4:e6:2d:d5:b6:ed, size:1460, heap:176160, flag:0[err:0x0, proto:0, tos:0][0m
[0;33mW (17106) mesh_main: [#RX:3/3][L:1] parent:10:07:b6:ac:a1:5d, receive from b4:e6:2d:d5:b6:ed, size:1460, heap:176160, flag:0[err:0x0, proto:0, tos:0][0m
[0;33mW (18106) mesh_main: [#RX:4/4][L:1] parent:10:07:b6:ac:a1:5d, receive from b4:e6:2d:d5:b6:ed, size:1460, heap:175056, flag:0[err:0x0, proto:0, tos:0][0m
Esp-Mesh "root not fixed"
Re: Esp-Mesh "root not fixed"
i did the changes but still it is showing same "root not fixed"..WiFive wrote: ↑Tue May 21, 2019 1:45 pmIt's a setting not an error
https://docs.espressif.com/projects/esp ... _fix_rootb
Users browsing this forum: Saichander and 189 guests
