Hey all,
Wondering if anyone can help here.
I've been having a few DNS failures which are due to the WiFi being delayed. Though, I'm a little confused at which priority the WiFi task is actually running at.
I can see in WiFiGeneric.cpp that ESP_TASKD_EVENT_PRIO applies -1 .
In esp_task.h, ESP_TASKD_EVENT_PRIO is equal to configMAX_PRIORITIES and applies - 5.
In FreeRTOSConfig configMAX_PRIORITIES is set to 7 or 25 depending on SMALL_TEST (not sure what this is).
I'm under the impression 7 is maximum from purposely trying to interfere with the WiFi by task priority. This would give a priority 7 - 6 = 1?
This seems very low as many other tasks seem to operate at this level. Am I missing something obvious here?
Thanks in advance..
Task Priority of WiFi
Re: Task Priority of WiFi
This is pretty old picture, but ass you can see it was priority 23 back then:
https://user-images.githubusercontent.c ... 86cfcd.png
Max priority is 25.
Max priority is 25.
Thanks for your help - it seems a fix was released last month which updated the priority from 2 to (ESP_TASKD_EVENT_PRIO -1).
https://github.com/espressif/arduino-es ... 99374f82a5
I've reinstalled my versions, so hopefully... it will fix the issue. Though, I should probably move over to IDF permanently with FreeRTOS.
Cheers,
Cheers,
Users browsing this forum: No registered users and 98 guests
