Formatting SD card
Humam Helfawi
Formatting SD card
Postby Humam Helfawi » Tue Apr 30, 2019 10:22 am
Is it possible to format an SD card as FAT32 at runtime using ESP-IDF ?
Thanks!
chegewara
Re: Formatting SD card
Postby chegewara » Wed May 01, 2019 9:38 am
* @brief Configuration arguments for esp_vfs_fat_sdmmc_mount and esp_vfs_fat_spiflash_mount functions
typedef struct {
* If FAT partition can not be mounted, and this parameter is true,
* create partition table and format the filesystem.
bool format_if_mount_failed;
int max_files; ///< Max number of open files
* If format_if_mount_failed is set, and mount fails, format the card
* with given allocation unit size. Must be a power of 2, between sector
* size and 128 * sector size.
* For SD cards, sector size is always 512 bytes. For wear_levelling,
* sector size is determined by CONFIG_WL_SECTOR_SIZE option.
* Using larger allocation unit size will result in higher read/write
* performance and higher overhead when storing small files.
* Setting this field to 0 will result in allocation unit set to the
* sector size.
size_t allocation_unit_size;
} esp_vfs_fat_mount_config_t;
// Compatibility definition
typedef esp_vfs_fat_mount_config_t esp_vfs_fat_sdmmc_mount_config_t;
Humam Helfawi
Postby Humam Helfawi » Fri May 03, 2019 11:58 am
typedef struct {
* sector size.
Thank you very muhc!
A32-1000
Postby A32-1000 » Thu Feb 18, 2021 12:31 pm
Still not really understand how to get it to format on runtime.
Having such a thing in an unreachable esp32cam would be great, when the data corrupts. (it happened..)
this is 'if mount fails'..
chegewara
Postby chegewara » Fri Feb 19, 2021 1:25 am
Users browsing this forum: Bing [Bot] and 139 guests
