ESP32 PICO KIT 4.1 - MTDI Pullup
RobStev0
Postby RobStev0 » Sat Apr 20, 2019 2:04 pm
According to the ESP32-PICO datasheet, the embedded SPI flash requires 3.3V from the internal LDO which would mean MTDI must be held low.
In the PICO Kit schematic available here: https://docs.espressif.com/projects/esp ... index.html
...R23 pulls MTDI high, which would force the LDO to 1.8V.
Is this a mistake? If not, what am I missing?
Followup question: Why are the RTS and CTS pins of the CP2104 connected to IO13 and IO15 instead of IO19 and IO22 (which are the correct U0 flow control pins).
Cheers.
ESP_krzychb
Contact:
Re: ESP32 PICO KIT 4.1 - MTDI Pullup
Postby ESP_krzychb » Sun Apr 21, 2019 12:37 pm
Hi RobStev0,
NC besides an element on schematic (e.g. R23) means that this element is "not connected".
SomeCallMeTim
Postby SomeCallMeTim » Fri Apr 26, 2019 6:46 pm
It's also possible to force 1.8V or 3.3V operation regardless of the MTDI pull status with an eFuse. See https://github.com/espressif/esptool/wi ... e-vdd_sdio.
Users browsing this forum: inF1704 and 48 guests
