[Solved] RMT collisions with UART?
u063096
Postby u063096 » Sat Apr 06, 2019 9:17 am
Solution: see next post!
Since the RMT reception problems I am experiencing always occur when some kind of UART communication is going on - either the Serial output to the PC via USB or display commands via UART2 to a Nextion HMI display - could there be any interference between RMT and UART?
The RMT is working like a charm as soon as I will disconnect both USB and display UART connections. When either of these is plugged in, the RMT gets seemingly less (USB) or no (display UART) data anymore.
Huh... :shock:
u063096
Re: [Solved] RMT collisions with UART?
Postby u063096 » Mon Apr 08, 2019 10:29 am
The problem was the 433MHz receiver module, not the ESP32.
The cheap receiver modules all are amplifying whatever they pick up to a level where they are "seeing" data signals. This is the reason why most 433MHz protocols are sending some lead bytes with a recognizable pattern to let the receivers adjust to the signal level, thus reducing the noise.
In my environment the LCD display added a _lot_ of low-amplitude noise, that got amplified until it prevented the lead-in pattern to be detected.
The solution was to solder a resistor to two pins of the chip on the receiver module, that now is lifting the reaction threshold of the amplifying circuit to a level above the noise. Works like a charm :D
I found two solutions for two of the most used modules:
fabltd
Postby fabltd » Mon Dec 02, 2019 5:25 pm
Hi
Do you have any info on how you got the RMT working. I am stuck but cannot find any help.
JT
Users browsing this forum: No registered users and 58 guests
