ESP32 firmware update over the internet?
Ritesh
Contact:
Re: ESP32 firmware update over the internet?
Postby Ritesh » Fri Mar 29, 2019 8:24 am
dhananjay.sutariya wrote:
Mon Mar 25, 2019 1:01 pm
If i want to do OTA without local server.
Are there any AWS platform (or any such) where i can upload my binary so that it can be fetched by my device.
In this might be ESP32 SDK Developer will help to you to provide support for external server like AWS cloud server or something like if feasible for you.
Otherwise you need to purchase it as per your requirement which you can do for one week or less than that much of time.
Regards,
Ritesh Prajapati
dhananjay.sutariya
Postby dhananjay.sutariya » Thu Apr 04, 2019 6:11 am
Okay Thanks Ritesh.
Regards,
Dhananjay Sutariya
Ritesh
Contact:
Postby Ritesh » Sun Apr 07, 2019 10:12 am
Okay Thanks Ritesh.
Regards,
Dhananjay Sutariya
Did you get support from external or looking to manage it by yourself?
Regards,
Ritesh Prajapati
dhananjay.sutariya
Postby dhananjay.sutariya » Mon Apr 08, 2019 7:29 am
Hi Ritesh,
We have a dedicated Server on which we can perform this OTA.
Thanks,
Dhananjay Sutariya
Ritesh
Contact:
Postby Ritesh » Thu Apr 11, 2019 3:59 am
Hi Ritesh,
Thanks,
Dhananjay Sutariya
Ok. So there is no any issue now to move further for this. correct? Let me know if you have still any issue regarding this
Regards,
Ritesh Prajapati
dhananjay.sutariya
Postby dhananjay.sutariya » Thu Apr 11, 2019 5:41 am
Hi Ritesh,
Thanks,
Dhananjay Sutariya
Hi Ritesh,
Not for the server but i'm having issues when i use the same native ota example outside its sample code.
Please Go through this :
https://stackoverflow.com/questions/556 ... my-fimware
Ritesh
Contact:
Postby Ritesh » Sat Apr 13, 2019 10:07 am
Hi Ritesh,
Thanks,
Dhananjay Sutariya
Hi Ritesh,
I am suggesting to create issue into ESP32 IDF Git Repository instead of posting into stack overflow.
Because, Issue is specific for ESP32 for which you might get quick response.
I have checked that stack overflow issue and it seems like you are not getting IP event after connecting your ESP32 device to router.
So, It is better to share logs for your issue and also I am suggesting to check with sample wifi example instead of checking with OTA example. So that we can have idea like is there any issue into hardware or device perspective or not.
Regards,
Ritesh Prajapati
DXK_1987
Postby DXK_1987 » Fri May 29, 2020 7:20 pm
Someone can post the necessary steps to update the ESP32 Firmware from a .bin file on a private server.
Users browsing this forum: Majestic-12 [Bot] and 114 guests
