espressif's "Chip7 2-2-A" spotted in the wild
EDITS:
what we know about - summarized :
a) in this version there is no 5 GHz but it is on the work
b) in this version is USB
c) TinyBASIC port in ROM?
no in this not but there is plan 4 versions of based on the new architecture
d) it is a Tensilica / RISC V are in the pipelines.
e) there are beta user / request possible
f) there is no CAP1 and CAP2 any more
...still in edit work this post ...
Hi folks ...
spotted in the wild :
rudi
Hi folks ...
rudi
Re: espressif's "Chip7 2-2-A" spotted in the wild
no guarantee! pure guess
rudi
rudi
So how many things from "What would you like to see in The Next Chip?" made it inside?
Not quite sure looking at picture - but is the chip size 2x bigger?
More cores? )
More cores? )
Hi WiFive
in advance:
Cause the name Chip7 2-2-A
i think there was a few month ago where few "engineer samples" are tested at espressif
cause here you find a hint :
"/home/cff/gittree/chip7.1_phy/chip_7.1/board_code/app_test/pp/phy/phy_chip_v7_ana.c"
also it can be mean, that we talk about the IP 7 ( RiscV ), 64Bit, 8 core, 5-6 Pipes, Atomic,
Linux compatible and further more
( i think it is a preview thing ( 2..4 core .. but i can image that is a 64 bit.. )
I think we get 5 GHz -
i think over the name at the bottom, UO0AN5V280, there are few infos perhabs in this?
U 64 Bit
O ??
0 ??
A Atomic
N Normal Mode no compressed for code density
5 5 stage variable pipeline
V Risc-V
2 Dual Core, Dual Wifi, Dual Wifi & BT/BLE
8 8 Core ?? 8 Mbit eMbeddedFlash ?? 8 MByte eMbeddedFlash ?? .. 8 mm package ??
0 ( No eMbedded Flash ?? )
we drill and keep looking further
rudi
in advance:
i think we are very flexible in this, cause it looks like we can configure each 47 IO 's like we want and need.WiFive wrote: ↑Wed Mar 20, 2019 12:39 pmSo how many things from "What would you like to see in The Next Chip?" made it inside?
U 64 Bit
O ??
0 ??
A Atomic
V Risc-V
rudi
New think over UO0AN5V280
U 64 Bit
O ??
0 ??
A Atomic
5 5 stage variable pipeline ?? 5 Core ( Quad 4xU7 + 1xS7 ) ??
V Risc-V
rudi
U 64 Bit
O ??
0 ??
A Atomic
V Risc-V
rudi
Chip 7 = 7nm
Just to temper expectations a bit: this is likely not going to be the top-of-the-line powerhouse that you guys think/hope it will be, as seen in the posts in this topic. Not saying we're not working on one of those but this is not it. (It does have a few picks from the ideas of the 'what would you like to see in the new chip' topic inside, though.)
hehe no 8 coresESP_Sprite wrote: ↑Thu Mar 21, 2019 7:22 am
Just to temper expectations a bit: this is likely not going to be the top-of-the-line powerhouse that you guys think/hope it will be, ..
edit:
would have been too nice -
but I also thought of a "new esp32"
So an improved and expanded.
he was announced
"FYI, there will be a new" ESP32 "next year."
/edit
it would be a tick to small for all the wishes and think on from the "What would you like to see in The Next Chip?" thread
do you can whisper about the RF filter? looks bodged. 5 GHz ?
can imagine that 5 GHz work here but not sure -
we continue to speculate
the design it self looks like an enlarged scope of esp32-wrover and more much more gpio
rudi
07 2019 - June 2019 ?
I think it says UO0AN6V280 - 6 or 8 cores?
Users browsing this forum: Baidu [Spider] and 62 guests
