- /* Play music from Bluetooth device
- This example code is in the Public Domain (or CC0 licensed, at your option.)
- Unless required by applicable law or agreed to in writing, this
- software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
- CONDITIONS OF ANY KIND, either express or implied.
- #include <string.h>
- #include "freertos/FreeRTOS.h"
- #include "freertos/task.h"
- #include "esp_log.h"
- #include "nvs_flash.h"
- #include "audio_element.h"
- #include "audio_pipeline.h"
- #include "audio_event_iface.h"
- #include "audio_common.h"
- #include "i2s_stream.h"
- #include "esp_peripherals.h"
- #include "periph_touch.h"
- #include "audio_hal.h"
- #include "board.h"
- #include "bluetooth_service.h"
- static const char *TAG = "BLUETOOTH_EXAMPLE";
- #define LYRAT_TOUCH_SET TOUCH_PAD_NUM9
- #define LYRAT_TOUCH_PLAY TOUCH_PAD_NUM8
- #define LYRAT_TOUCH_VOLUP TOUCH_PAD_NUM7
- #define LYRAT_TOUCH_VOLDWN TOUCH_PAD_NUM4
- //状态切换
- volatile uint8_t ex_audio_status = 1;
- void app_main(void)
- audio_pipeline_handle_t pipeline1, pipeline2;
- audio_element_handle_t bt_stream_reader ,i2s_stream_reader, i2s_stream_writer1,i2s_stream_writer2;
- //nvs flash初始化
- esp_err_t err = nvs_flash_init();
- if (err == ESP_ERR_NVS_NO_FREE_PAGES) {
- // NVS partition was truncated and needs to be erased
- // Retry nvs_flash_init
- ESP_ERROR_CHECK(nvs_flash_erase());
- err = nvs_flash_init();
- //日志级别打印
- esp_log_level_set("*", ESP_LOG_INFO);
- esp_log_level_set(TAG, ESP_LOG_DEBUG);
- //1.创建蓝牙服务
- ESP_LOGI(TAG, "[ 1 ] Create Bluetooth service");
- bluetooth_service_cfg_t bt_cfg = {
- .device_name = "ESP-ADF-SPEAKER",
- .mode = BLUETOOTH_A2DP_SINK,
- bluetooth_service_start(&bt_cfg);
- //2.启动编解码器芯片
- ESP_LOGI(TAG, "[ 2 ] Start codec chip");
- audio_hal_codec_config_t audio_hal_codec_cfg = AUDIO_HAL_ES8388_DEFAULT();
- audio_hal_codec_cfg.i2s_iface.samples = AUDIO_HAL_44K_SAMPLES;
- //音频输入设置把麦克风改成外部音频输入
- audio_hal_codec_cfg.adc_input = AUDIO_HAL_ADC_INPUT_LINE2;
- audio_hal_handle_t hal = audio_hal_init(&audio_hal_codec_cfg, 0);
- audio_hal_ctrl_codec(hal, AUDIO_HAL_CODEC_MODE_DECODE, AUDIO_HAL_CTRL_START);
- //3.创建音频管道以进行播放
- ESP_LOGI(TAG, "[ 3 ] Create audio pipeline for playback");
- audio_pipeline_cfg_t pipeline_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
- pipeline1 = audio_pipeline_init(&pipeline_cfg);
- pipeline2 = audio_pipeline_init(&pipeline_cfg);
- //3.1.创建i2s流以将数据写入编解码器芯片
- ESP_LOGI(TAG, "[3.1] Create i2s stream to read audio data from codec chip");
- i2s_stream_cfg_t i2s_r_cfg = I2S_STREAM_CFG_DEFAULT();
- i2s_r_cfg.type = AUDIO_STREAM_READER;
- i2s_stream_reader = i2s_stream_init(&i2s_r_cfg);
- //3.2.创建i2s流以将数据写入编解码器芯片
- ESP_LOGI(TAG, "[3.2] Create i2s stream to write data to codec chip");
- i2s_stream_cfg_t i2s_w_cfg1 = I2S_STREAM_CFG_DEFAULT();
- i2s_w_cfg1.type = AUDIO_STREAM_WRITER;
- i2s_w_cfg1.i2s_config.sample_rate = 48000;
- i2s_stream_writer1 = i2s_stream_init(&i2s_w_cfg1);
- //3.2.1.创建i2s流以将数据写入编解码器芯片
- i2s_stream_cfg_t i2s_w_cfg2 = I2S_STREAM_CFG_DEFAULT();
- i2s_w_cfg2.type = AUDIO_STREAM_WRITER;
- i2s_w_cfg2.i2s_config.sample_rate = 48000;
- i2s_stream_writer2 = i2s_stream_init(&i2s_w_cfg2);
- //3.3.获取蓝牙流
- ESP_LOGI(TAG, "[3.3] Get Bluetooth stream");
- bt_stream_reader = bluetooth_service_create_stream();
- //3.4.初始化外围设备
- ESP_LOGI(TAG, "[ 3.4 ] Register all elements to audio pipeline");
- audio_pipeline_register(pipeline1, bt_stream_reader, "bt");
- audio_pipeline_register(pipeline1, i2s_stream_writer1, "i2sw1");
- audio_pipeline_register(pipeline2, i2s_stream_reader, "i2sr");
- audio_pipeline_register(pipeline2, i2s_stream_writer2, "i2sw2");
- //3.5.把它链接在一起
- ESP_LOGI(TAG, "[ 3.5 ] Link elements together");
- audio_pipeline_link(pipeline1, (const char *[]) {"bt", "i2sw1"}, 2);
- audio_pipeline_link(pipeline2, (const char *[]) {"i2sr", "i2sw2"}, 2);
- //4.初始化外围设备
- ESP_LOGI(TAG, "[ 4 ] Initialize peripherals");
- esp_periph_config_t periph_cfg = { 0 };
- esp_periph_init(&periph_cfg);
- //4.1.初始化Touch外围设备
- ESP_LOGI(TAG, "[4.1] Initialize Touch peripheral");
- periph_touch_cfg_t touch_cfg = {
- .touch_mask = TOUCH_SEL_SET | TOUCH_SEL_PLAY | TOUCH_SEL_VOLUP | TOUCH_SEL_VOLDWN,
- .tap_threshold_percent = 70,
- esp_periph_handle_t touch_periph = periph_touch_init(&touch_cfg);
- //4.2.创建蓝牙外设
- ESP_LOGI(TAG, "[4.2] Create Bluetooth peripheral");
- esp_periph_handle_t bt_periph = bluetooth_service_create_periph();
- //4.2.启动所有外围设备
- ESP_LOGI(TAG, "[4.2] Start all peripherals");
- esp_periph_start(touch_periph);
- esp_periph_start(bt_periph);
- //5.设置事件监听器
- ESP_LOGI(TAG, "[ 5 ] Setup event listener");
- audio_event_iface_cfg_t evt_cfg = AUDIO_EVENT_IFACE_DEFAULT_CFG();
- audio_event_iface_handle_t evt1 = audio_event_iface_init(&evt_cfg);
- audio_event_iface_handle_t evt2 = audio_event_iface_init(&evt_cfg);
- ESP_LOGI(TAG, "[5.1] Listening event from all elements of pipeline");
- //为此音频管道设置事件监听器,来自此管道的任何事件都可以通过`evt`监听
- audio_pipeline_set_listener(pipeline1, evt1);
- audio_pipeline_set_listener(pipeline2, evt2);
- //5.2.外围设备的监听事件
- ESP_LOGI(TAG, "[5.2] Listening event from peripherals");
- audio_event_iface_set_listener(esp_periph_get_event_iface(), evt1);
- audio_event_iface_set_listener(esp_periph_get_event_iface(), evt2);
- while(1)
- switch(ex_audio_status)
- case 0:
- ESP_LOGI(TAG, "case 0");
- //6.启动audio_pipeline
- ESP_LOGI(TAG, "[ 6 ] Start audio_pipeline");
- audio_pipeline_run(pipeline1);
- //7.监听所有管道事件
- ESP_LOGI(TAG, "[ 7 ] Listen for all pipeline events");
- while (1)
- audio_event_iface_msg_t msg;
- esp_err_t ret1 = audio_event_iface_listen(evt1, &msg, portMAX_DELAY);
- if (ret1 != ESP_OK) {
- ESP_LOGE(TAG, "[ * ] Event interface error : %d", ret1);
- continue;
- if (msg.cmd == AEL_MSG_CMD_ERROR) {
- ESP_LOGE(TAG, "[ * ] Action command error: src_type:%d, source:%p cmd:%d, data:%p, data_len:%d",
- msg.source_type, msg.source, msg.cmd, msg.data, msg.data_len);
- if (msg.source_type == AUDIO_ELEMENT_TYPE_ELEMENT && msg.source == (void *) bt_stream_reader
- && msg.cmd == AEL_MSG_CMD_REPORT_MUSIC_INFO) {
- audio_element_info_t music_info = {0};
- audio_element_getinfo(bt_stream_reader, &music_info);
- ESP_LOGI(TAG, "[ * ] Receive music info from Bluetooth, sample_rates=%d, bits=%d, ch=%d",
- music_info.sample_rates, music_info.bits, music_info.channels);
- audio_element_setinfo(i2s_stream_writer1, &music_info);
- i2s_stream_set_clk(i2s_stream_writer1, music_info.sample_rates, music_info.bits, music_info.channels);
- continue;
- if (msg.source_type == PERIPH_ID_TOUCH
- && msg.cmd == PERIPH_TOUCH_TAP
- && msg.source == (void *)touch_periph) {
- if ((int) msg.data == TOUCH_PLAY) {
- ESP_LOGI(TAG, "[ * ] [Play] touch tap event");
- periph_bluetooth_play(bt_periph);
- } else if ((int) msg.data == TOUCH_SET) {
- ESP_LOGI(TAG, "[ * ] [Set] touch tap event");
- periph_bluetooth_pause(bt_periph);
- } else if ((int) msg.data == TOUCH_VOLUP) {
- if(audio_pipeline_pause(pipeline2) != ESP_OK)
- ESP_LOGI(TAG, "[ * ] audio_pipeline_pause err");
- if(audio_pipeline_run(pipeline1) != ESP_OK)
- ESP_LOGI(TAG, "[ * ] audio_pipeline_run err");
- } else if ((int) msg.data == TOUCH_VOLDWN) {
- ESP_LOGI(TAG, "[ * ] [Vol-] touch tap event");
- ex_audio_status = 1;
- if(audio_pipeline_pause(pipeline1) != ESP_OK)
- break;
- /* Stop when the Bluetooth is disconnected or suspended */
- if (msg.source_type == PERIPH_ID_BLUETOOTH
- && msg.source == (void *)bt_periph) {
- if (msg.cmd == PERIPH_BLUETOOTH_DISCONNECTED) {
- ESP_LOGW(TAG, "[ * ] Bluetooth disconnected");
- break;
- /* Stop when the last pipeline element (i2s_stream_writer in this case) receives stop event */
- if (msg.source_type == AUDIO_ELEMENT_TYPE_ELEMENT && msg.source == (void *) i2s_stream_writer1
- && msg.cmd == AEL_MSG_CMD_REPORT_STATUS && (int) msg.data == AEL_STATUS_STATE_STOPPED) {
- ESP_LOGW(TAG, "[ * ] Stop event received");
- break;
- break;
- case 1:
- audio_pipeline_run(pipeline2);
- while (1)
- ESP_LOGI(TAG, "case 1");
- audio_event_iface_msg_t msg2;
- esp_err_t ret2 = audio_event_iface_listen(evt2, &msg2, portMAX_DELAY);
- if (ret2 != ESP_OK) {
- ESP_LOGE(TAG, "[ * ] Event interface error : %d", ret2);
- continue;
- if (msg2.cmd == AEL_MSG_CMD_ERROR) {
- msg2.source_type, msg2.source, msg2.cmd, msg2.data, msg2.data_len);
- if (msg2.source_type == PERIPH_ID_TOUCH
- && msg2.cmd == PERIPH_TOUCH_TAP
- && msg2.source == (void *)touch_periph) {
- if ((int) msg2.data == TOUCH_PLAY) {
- } else if ((int) msg2.data == TOUCH_SET) {
- } else if ((int) msg2.data == TOUCH_VOLUP) {
- } else if ((int) msg2.data == TOUCH_VOLDWN) {
- ex_audio_status = 0;
- break;
- if (msg2.source_type == AUDIO_ELEMENT_TYPE_ELEMENT && msg2.source == (void *) i2s_stream_writer2
- && msg2.cmd == AEL_MSG_CMD_REPORT_STATUS && (int) msg2.data == AEL_STATUS_STATE_STOPPED) {
- break;
- break;
建立双管道时候,按键外设的问题
建立双管道时候,按键外设的问题
我这边做了一个简单的双管道demo,想通过按键的事件进行切换。管道1是连接bt播放音乐,管道2是连接AUX_IN播放音乐,硬件为ESP32_LyraT v4.3。但是使用管道2时却触发不到按键的事件,是想请问下我代码的哪个步骤出了问题。
Re: 建立双管道时候,按键外设的问题
我根据了“flexible_pipeline”例程的逻辑重新改了代码,如下。
发现几个问题
1、audio_pipeline_pause得换成audio_pipeline_stop+audio_pipeline_wait_for_stop才可用
2、得重新注册i2s_stream_writer——audio_pipeline_register(pipeline, i2s_stream_writer, "i2sw");
但是audio_pipeline_stop注释不是说了“The link state of the elements in the pipeline is kept”吗?不清楚什么时候取消注册的
发现几个问题
- * 文件名称:play_bt_music_example.c
- * 作 者:Kyle
- * 日 期:20190319
- * 描 述:bt与aux_in音频切换
- /* 头文件 --------------------------------------------------------------------*/
- #include "periph_button.h"
- /* 宏定义 --------------------------------------------------------------------*/
- /* 变量 ----------------------------------------------------------------------*/
- //状态切换
- bool ex_audio_status = false;
- audio_pipeline_handle_t pipeline;
- audio_element_handle_t bt_stream_reader, i2s_stream_reader, i2s_stream_writer;
- /* 函数定义 ------------------------------------------------------------------*/
- * 函数名称:app_main
- * 作 者:Kyle
- * 日 期:20190319
- * 描 述:主函数
- * 输入参数:无
- * 返 回 值:无
- //nvs flash初始化
- //1.创建蓝牙服务
- //2.启动编解码器芯片
- //3.创建音频管道以进行播放
- pipeline = audio_pipeline_init(&pipeline_cfg);
- //3.1.创建i2s流以将数据从编解码器芯片读取
- ESP_LOGI(TAG, "[3.1] Create i2s stream to read data to codec chip");
- i2s_stream_cfg_t i2sr_cfg = I2S_STREAM_CFG_DEFAULT();
- i2sr_cfg.type = AUDIO_STREAM_READER;
- i2s_stream_reader = i2s_stream_init(&i2sr_cfg);
- ESP_LOGI(TAG, "[3.1] Create i2s stream to write data to codec chip");
- i2s_stream_cfg_t i2sw_cfg = I2S_STREAM_CFG_DEFAULT();
- i2sw_cfg.type = AUDIO_STREAM_WRITER;
- i2s_stream_writer = i2s_stream_init(&i2sw_cfg);
- //3.3.获取蓝牙流
- ESP_LOGI(TAG, "[3.2] Get Bluetooth stream");
- //3.2.将所有元素注册到音频管道
- ESP_LOGI(TAG, "[3.2] Register all elements to audio pipeline");
- audio_pipeline_register(pipeline, i2s_stream_reader, "i2sr");
- audio_pipeline_register(pipeline, i2s_stream_writer, "i2sw");
- audio_pipeline_register(pipeline, bt_stream_reader, "bt");
- //3.3.把它链接在一起
- ESP_LOGI(TAG, "[3.3] Link it together [Bluetooth]-->bt_stream_reader-->i2s_stream_writer-->[codec_chip]");
- audio_pipeline_link(pipeline, (const char *[]) {"i2sr", "i2sw"}, 2);
- //4.初始化外围设备
- //4.1.初始化button外围设备
- ESP_LOGI(TAG, "[4.1] Initialize button peripheral");
- periph_button_cfg_t btn_cfg = {
- .gpio_mask = GPIO_SEL_36 | GPIO_SEL_39, // REC BTN & MODE BTN
- esp_periph_handle_t button_periph = periph_button_init(&btn_cfg);
- //4.2.创建蓝牙外设
- //4.2.启动所有外围设备
- esp_periph_start(button_periph);
- //5.设置事件监听器
- audio_event_iface_handle_t evt = audio_event_iface_init(&evt_cfg);
- //5.1.来自管道的所有元素的监听事件
- audio_pipeline_set_listener(pipeline, evt);
- //5.2.外围设备的监听事件
- audio_event_iface_set_listener(esp_periph_get_event_iface(), evt);
- audio_pipeline_run(pipeline);
- //7.监听所有管道事件
- while (1) {
- esp_err_t ret = audio_event_iface_listen(evt, &msg, portMAX_DELAY);
- if (ret != ESP_OK) {
- ESP_LOGE(TAG, "[ * ] Event interface error : %d", ret);
- continue;
- if (msg.source_type != PERIPH_ID_BUTTON) {
- // audio_element_handle_t el = (audio_element_handle_t)msg.source;
- // ESP_LOGI(TAG, "Element tag:[%s],src_type:%x, cmd:%d, data_len:%d, data:%p",
- // audio_element_get_tag(el), msg.source_type, msg.cmd, msg.data_len, msg.data);
- continue;
- if (((int)msg.data == GPIO_MODE) && (msg.cmd == PERIPH_BUTTON_PRESSED)){
- ex_audio_status = !ex_audio_status;
- if (!ex_audio_status) {
- audio_pipeline_stop(pipeline);
- audio_pipeline_wait_for_stop(pipeline);
- ESP_LOGE(TAG, "Changing music to %s", ex_audio_status ? "bt" : "i2sr");
- if (ex_audio_status) {
- audio_pipeline_breakup_elements(pipeline, i2s_stream_reader);
- //蓝牙
- audio_pipeline_relink(pipeline, (const char *[]) {"bt", "i2sw"}, 2);
- } else {
- audio_pipeline_breakup_elements(pipeline, bt_stream_reader);
- //外部
- audio_pipeline_relink(pipeline, (const char *[]) {"i2sr", "i2sw"}, 2);
- audio_pipeline_resume(pipeline);
- //8.停止audio_pipeline
- ESP_LOGI(TAG, "[ 8 ] Stop audio_pipeline");
- audio_pipeline_terminate(pipeline);
- audio_pipeline_unregister(pipeline, bt_stream_reader);
- audio_pipeline_unregister(pipeline, i2s_stream_reader);
- audio_pipeline_unregister(pipeline, i2s_stream_writer);
- //在删除侦听器之前终止管道
- /* Terminate the pipeline before removing the listener */
- audio_pipeline_remove_listener(pipeline);
- //在删除侦听器之前停止所有外围设备
- /* Stop all peripherals before removing the listener */
- esp_periph_stop_all();
- audio_event_iface_remove_listener(esp_periph_get_event_iface(), evt);
- //确保在销毁event_iface之前调用audio_pipeline_remove_listener和audio_event_iface_remove_listener
- /* Make sure audio_pipeline_remove_listener & audio_event_iface_remove_listener are called before destroying event_iface */
- audio_event_iface_destroy(evt);
- //释放所有资源
- /* Release all resources */
- audio_pipeline_deinit(pipeline);
- audio_element_deinit(bt_stream_reader);
- audio_element_deinit(i2s_stream_reader);
- audio_element_deinit(i2s_stream_writer);
- esp_periph_destroy();
- bluetooth_service_destroy();
Users browsing this forum: No registered users and 12 guests
