BT memory consumption
fturker
Postby fturker » Wed Dec 13, 2017 12:58 pm
Hi everyone,
I am working on ble mqtt gateway with ESP32 BLE+WIFI. When i start wifi after start scan permenantly, i can found beacons around and send this beacons informations to mqtt broker inside json packet. But sometimes i am getting error about BT memory consumption from BTC task. The error is: "host_recv_pkt_cb couldn't acquire memory for inbound data buffer". How can i fix that error. I looked this in google but i did not found any relevant solution. Plese help me for fix this problem. Thanks for your advice...
cyberman54
Re: BT memory consumption
Postby cyberman54 » Wed Apr 18, 2018 8:59 pm
I ran into the same problem.
Did you find a solution for it?
chefotm
Postby chefotm » Fri May 04, 2018 5:23 am
Im tried the malloc from PSRAM option in Bluetooth menuconfig. And use the dynamic memory allocation. It will free up many space. You can optimize that library consumption in the menuconfig turning off features you will never use (and for example closing the bluedroid stock log print). Bluetooth is such a Big consumer :). If you are using SSL on wifi, search for buffer sizes. They are gorgeous big.
arunbm123
Postby arunbm123 » Thu Mar 14, 2019 5:16 am
hi
I am having same problem
what the solution mr.fturker
Users browsing this forum: Majestic-12 [Bot] and 87 guests
