External supply
simone91
External supply
Postby simone91 » Mon Mar 11, 2019 7:30 pm
I want to use an ESP32 with an external supply.
For the moment I used an alcaline battery 9v 600mAh, and run correctly. It' s enough? How long it can supply my circuit?
Someone have another advice for the external supply? I would like to use a battery as small as possible.
AshIsPurestWhite
Re: External supply
Postby AshIsPurestWhite » Tue Mar 12, 2019 3:31 am
Using a efficient buck IC will help a lot. And what task you run may have a big impact for the battery life. You can measure the power consumption and the battery life by yourself. I think it's not too hard to operate.
MXKx20
Re: External supply
Postby MXKx20 » Tue Mar 12, 2019 6:20 am
Any rechargeable options with small Li Batteries?
simone91
Re: External supply
Postby simone91 » Tue Mar 12, 2019 9:32 pm
The duration of the is about 4-5 hours... I will find a source that can power it for 20 hours.
Can you advice me?
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 43 guests
