IP4_ADDR(&info.gw, 192, 168, 1, 1);//ESP acts as router, so gw addr will be its own addr
Hi WiFive,WiFive wrote: ↑Thu Feb 28, 2019 8:52 amSet this to 0 otherwise your phone will try to send internet traffic thereCode: Select all
Ok. Understood.
Trying either option on ESP IDF 3.3 still results in there being a DNS server on 192.168.4.1, but the gateway on 192.168.4.1 disappears. Android still doesn't use cellular in this case.phatpaul wrote: ↑Tue Feb 26, 2019 4:34 pmInteresting about the Garmin device. What device is it? Does it prevent hijacking the internet connection on both iOS and Android?
Here's what I have after struggling with this as well. It seems to work for iOS, but not always working in Android.
this is in main() before initializing WiFi:Hope it helps.Code: Select all
tcpip_adapter_init(); { tcpip_adapter_ip_info_t info = {0}; tcpip_adapter_dns_info_t dns_info = {0}; IP_ADDR4(&dns_info.ip, 0, 0, 0, 0); IP4_ADDR(&info.ip, 192, 168, 4, 1); IP4_ADDR(&info.gw, 0, 0, 0, 0); IP4_ADDR(&info.netmask, 255, 255, 255, 0); ESP_ERROR_CHECK(tcpip_adapter_dhcps_stop(TCPIP_ADAPTER_IF_AP)); ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &info)); dhcps_dns_setserver(&(dns_info.ip)); uint8_t opt_val = 0; // don't supply a dns server via dhcps //ESP_ERROR_CHECK(tcpip_adapter_dhcps_option(TCPIP_ADAPTER_OP_SET, TCPIP_ADAPTER_DOMAIN_NAME_SERVER, &opt_val, 1)); // don't supply a dns server via dhcps ESP_ERROR_CHECK(tcpip_adapter_dhcps_option(TCPIP_ADAPTER_OP_SET, TCPIP_ADAPTER_ROUTER_SOLICITATION_ADDRESS, &opt_val, 1)); // don't supply a gateway (router) via dhcps option 3 ESP_ERROR_CHECK(tcpip_adapter_dhcps_start(TCPIP_ADAPTER_IF_AP)); }
Users browsing this forum: prothan and 93 guests
