Problems connecting to WiFi
Re: Problems connecting to WiFi
Checked out everything again and still there is no difference.
Deti
Deti
Interesting... I'm doing tests based on a totally fresh install of everything from Github, etc. as of a few hours ago, on a machine that didn't previously have any of this on it.
Working through the esp-idf/examples/03_http_request example, I'm encountering the same exact issue:
My SSID and password are normal ASCII and shouldn't be an issue - other devices (Particle Photon, Raspberry Pi, various appliances, phones, laptops and so on) have no problem connecting to this.
I even added a "esp_wifi_set_country(WIFI_COUNTRY_US)" call just in case that would affect things - no change.
Perhaps this is a new issue? Has this worked for others previously?
I (x) wifi: n:11 0, o:11 0, ap:255 255, sta:11 0, prof:1
I (x) wifi: state: init -> auth (b0)
I (x) wifi: state: auth -> init (2)
I've opened an issue regarding this problem:
https://github.com/espressif/esp-idf/issues/207
For me it worked after checking out tag "v1.0".deti__ wrote:Checked out everything again and still there is no difference.
Deti
git fetch --all --tags --prune
git checkout tag/v1.0
Hi Malte,
thank you very much for your help - it works now! Originally I followed the instructions in https://github.com/espressif/esp-idf/bl ... -setup.rst
Why did nobody tell that the SDK is broken currently?
Deti
Deti
I thought so, too. But when you checkout master again it is still working, isn't it?deti__ wrote: Why did nobody tell that the SDK is broken currently?
I don't think this brings you up to the master (at least in the recursively fetched remote repositories).
Deti
Deti
no, it's just about checking out the esp-idf master and then doing a git submodule update to checkout the referenced versions.
I am not trying to checkout all master branches in the submodules!
After some tests I found out, that it is necessary to fully erase the flash memory by issuing the command
~/esp/esp-idf/components/esptool_py/esptool/esptool.py --port /dev/ttyUSB0 erase_flash
Now make flash works properly.
Further reading: https://nodemcu.readthedocs.io/en/maste ... -init-data
Deti
Deti
Hi Deti,
(BTW, you can erase flash from esp-idf itself via 'make erase_flash')
Angus
To clarify, are you saying that you couldn't connect to WiFi before you completely erased flash? Or is this related to some other problem? Is this on current 'master', or 'v1.0'?deti__ wrote:After some tests I found out, that it is necessary to fully erase the flash memory by issuing the command
Angus
Users browsing this forum: nopnop2002 and 95 guests
