Wear Levelling library sector size
burkulesomesh43
Postby burkulesomesh43 » Sat Sep 01, 2018 4:22 pm
Hi all,
I am comfused about choosing the sector size in wear levelling example.
I want to use near about 250kb of flash for file system so I have to use sector size 512kb because 4096kb sector size rquires minimum 512kb of flash for file system.
but I actually very confused that what is the difference in this sector sizes(CONFIG_WL_SECTOR_SIZE 512kb & 4096kb)?
Somesh Burkule
falke5
Re: Wear Levelling library sector size
Postby falke5 » Sun Feb 24, 2019 10:43 am
as i know its a byte, not kilobytes
Ritesh
Contact:
Postby Ritesh » Mon Feb 25, 2019 2:30 am
Hi all,
Yes. ESP32 SPI Flash sector size is 4096 Bytes only. So, You need to erase minimum 4096 bytes to write data into particular section.
So, your assumption is not correct as per your calculation.
Please find below link for more details regarding that.
https://docs.espressif.com/projects/esp ... flash.html
Let me know if you still have any confusion or doubt for that.
Regards,
Ritesh Prajapati
burkulesomesh43
Postby burkulesomesh43 » Tue Jun 11, 2019 10:30 am
Hi all,
Got it.
Thank you.
Somesh Burkule
Users browsing this forum: abbas1375 and 66 guests
