How to reconnect MQTT with new config
adam_ohara
Postby adam_ohara » Fri Feb 15, 2019 11:58 am
Hi
I am trying to change the config of my MQTT client and reconnect to the broker, as the username and password can be changed. This is over a TLS connection. Currently, I am trying:
        mqtt_config.username = mqtt_username;
        mqtt_config.password = mqtt_password;
        ESP_LOGI(TAG, "Password set to %s", mqtt_password);
        //Swap config and restart client
        if(started){
            esp_mqtt_client_stop(mqtt_client);
            esp_mqtt_set_config(mqtt_client, &mqtt_config);
            esp_mqtt_client_start(mqtt_client);
However, I get the following:
E (1666107) MQTT_CLIENT: Client has not connected
E (1668167) esp-tls: mbedtls_ssl_setup returned -0x7f00
E (1668167) esp-tls: Failed to open new connection
E (1668167) TRANS_SSL: Failed to open a new connection
E (1668177) MQTT_CLIENT: Error transport connect
Does anyone have any suggestions?
The MQTT client that was originally set wasn't connected to the broker in the first place, but it looks like it keeps trying until I do the above. Do I need to create a completely new config for doing this, or is config re-use OK?
Any help will be greatly appreciated.
ESP_cermak
Re: How to reconnect MQTT with new config
Postby ESP_cermak » Sat Feb 16, 2019 9:24 am
esp-mqtt library has recently been updated to support runtime update of configurations (specifically commit https://github.com/espressif/esp-mqtt/c ... b3eaa5ba15)
Updating the broker uri could be done:
        esp_mqtt_client_set_uri(mqtt_client, CONFIG_NEW_BROKER_URI);
Current master of esp-idf does not yet reference this updated mqtt, but that should be fixed soon (+ example added)
Users browsing this forum: Baidu [Spider] and 107 guests
