PWM with ESP32-Lyrat
pierreantoine
Postby pierreantoine » Thu Jan 31, 2019 1:54 pm
What would be the best way to add more pins such as GPIO and PWM to an ESP32-Lyrat dev board ?
Is there some extension boards or even a possibility to make it communicate with an Arduino nano for example ?
Thanks !
jason.mao
Re: PWM with ESP32-Lyrat
Postby jason.mao » Fri Feb 01, 2019 2:33 am
Hi
There are two pins(IO12 and IO 13) can be free use, firstly SDCARD set 1 line mode, then set the switch(J18) pin4 and pin5 ON, `JT_IO13_MTCK` and `JT_IO12_MTDI` can be used by J19. Hope to help you.
Thanks.
pierreantoine
Postby pierreantoine » Fri Feb 01, 2019 11:27 am
Thanks !
Unfortunately I would need 4 PWM pins + 1 I/O.
Do you think I can manage to connect another small extension board ?
kangasp
Postby kangasp » Tue Apr 23, 2019 6:10 pm
I know this post is a bit old, but thought I'd add this.
There's an available I2C port on the Lyrat. So, a board like this might meet your needs.
SparkFun 16 Output I/O Expander Breakout - SX1509
https://www.sparkfun.com/products/13601 ... 1555614610
Users browsing this forum: No registered users and 33 guests
