nvs_set_blob issue with UART interrupt enabled
amruta
Postby amruta » Wed Jan 30, 2019 11:17 am
We have an application running both BLE and WiFi. MQTT is used to communicate with server. It uses UART read interrupt to communicate with a third party device.
We are trying to read/write data in nvs memory. NVS read is working fine but while writing it gets stuck and control never returns back from nvs_set_blob.
Disabling UART interrupt before nvs write had no effect. Calling uart_driver_delete seems to be working. Is there any other way to do this?
ESP IDF: v3.1-dirty
Below is the UART configuration used
    uart_config_t uart_config = {
        .baud_rate = 4800,
        .data_bits = UART_DATA_8_BITS,
        .parity = UART_PARITY_EVEN,
        .stop_bits = UART_STOP_BITS_1,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE};
    uart_param_config(UART_NUM_2, &uart_config);
    uart_set_pin(UART_NUM_2, 17, 16, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
    uart_driver_install(UART_NUM_2, 1024* 2, 0, 0, NULL, 0);
    uart_set_line_inverse(UART_NUM_2, UART_INVERSE_TXD | UART_INVERSE_RXD);
    uart_isr_free(UART_NUM_2);
    uart_isr_register(UART_NUM_2, uart2_isr, NULL, ESP_INTR_FLAG_IRAM, &uart2_intr_handle);
Partition table
otadata,  data, ota,     0xd000,  0x2000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  app,  ota_0,   0x10000, 0x178000,
ota_1,    app,  ota_1,   ,        0x178000,
nvs,      data, nvs,     ,        0x10000,
ESP_Angus
Re: nvs_set_blob issue with UART interrupt enabled
Postby ESP_Angus » Wed Jan 30, 2019 10:39 pm
Hi amruta,
Without seeing all the code it's hard to tell what the problem could be.
Are you calling nvs_set_blob from a task, or from inside the UART ISR? NVS APIs are not safe to use from interrupts.
If it's a task, is there a chance it's deadlocking with something that happens inside the ISR?
ESP_Angus
Postby ESP_Angus » Wed Jan 30, 2019 10:45 pm
Ah, one other very likely thing I didn't spot the first time:
Are you sure that all of the code that can possibly be called from uart2_isr is in IRAM? If not, problems can occur while writing to flash and this could cause the exact symptom you're seeing (although more likely a panic handler crash, it's not guaranteed).
Try removing the ESP_INTR_FLAG_IRAM flag (set the flags value to 0) and see if the problem goes away. Without this flag, any UART interrupts that occur during an NVS write will be processed after the NVS write completes. With this flag, the interrupt will be processed immediately but must take care that only code/data in IRAM/DRAM is accessed.
More details can be found at https://docs.espressif.com/projects/esp ... t-handlers
amruta
Postby amruta » Sat Feb 13, 2021 12:28 pm
You are right !
ESP_INTR_FLAG_IRAM was the problem
And sorry for the (super) delayed reply
Users browsing this forum: Baidu [Spider], Google [Bot], Majestic-12 [Bot] and 97 guests
