No, It won't disconnect for such a long duration while connecting to new AP connection but it might happened that your device won't find AP then it will keep searching for AP with all possible channel then at that time there might be chances loosing device AP connection with that duration.Oromis wrote: ↑Tue Jan 29, 2019 12:16 pmNo, it doesn't happen every single time, but in about 90% of cases. So it very rarely works as intended.I just want to clarify that are you facing issue every time while commissioning WiFi credentials means LWIP listening socket is going to break when attempting to connect to WiFi access point?
Sure, I've been thinking about this as well. But is it really possible that establishing a new connection in STA mode completely stalls the AP interface for such a long time?Also, Just FYI, There might be chances to drop messages when you are trying to do communication into both AP and STA mode at a time because WiFi Radio is common for both STA and AP Interface.
LWIP listening socket breaks when attempting to connect to WiFi access point
Re: LWIP listening socket breaks when attempting to connect to WiFi access point
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: No registered users and 61 guests
