Enterprise authentication for mesh root not supported yet
ybuyankin
Postby ybuyankin » Thu Jan 10, 2019 5:24 pm
It looks like there is no support for the enterprise (e.g. PEAP-MSCHAP) authentication for the mesh root WiFi connection, right? Any plans on implementing it? So far I'm using quite an ugly workaround pre-connecting the root and then providing incorrect router setup to the mesh, that's not really a way to do that. Should not be too complicated as it basically supported by ESP-IDF, you just need to provide a way to pass the correct parameters there but as long as it's not open-source we can't do it ourselves.
Thanks,
--yuri
ESP_LBB
Re: Enterprise authentication for mesh root not supported yet
Postby ESP_LBB » Thu Jan 31, 2019 11:32 am
Hi yuri,
Enterprise authentication should be supported already in ESP-MESH, as you said it's based on ESP-IDF.
Could you share more information about your problem? Some related logs will be appraciated. We will feedback after the Chinese New Year Holiday.
Bangbang
Users browsing this forum: No registered users and 60 guests
