NT35510 Based Display
I saw in the repo that displays based on this driver are supported but I can't find any example LCDs that have been used or testing. This driver supports slightly larger screens (up to 5") with resolutions of 480 x 800 which is rather attractive. I assume with that high of a resolution we would have to use 8-bit mode (if possible) but I'd like to see an example of this working before I order parts and try anything.
Re: NT35510 Based Display
Thank you for pointing those out to me. Could you also tell me what LCD was used in those examples? Maybe this one: https://www.aliexpress.com/item/IPS-4-3 ... el=twinner
OK,we use this.
I'm sorry, but I wanted to make sure that I understand your response. Are you confirming that the display I found is the one that is used in the example code?
OK,we use this screen that you refered.
