when to provide spi peripherals driver?
now,only have spi-flash driver
Re: when to provide spi peripherals driver?
The SPI master driver will be in esp-idf v2.0, due for release in the next two weeks.
At that time can provide spi DMA Interruption example ?ESP_Angus wrote:The SPI master driver will be in esp-idf v2.0, due for release in the next two weeks.
The SPI driver will actually be fully capable of interrupt-driven DMA transfers. You basically feed it the transfers you want it to do using a queue and it will give you back the transfers it finished using another queue.
Thanks for your swift responseESP_Sprite wrote:The SPI driver will actually be fully capable of interrupt-driven DMA transfers. You basically feed it the transfers you want it to do using a queue and it will give you back the transfers it finished using another queue.
The SPI master driver is now available in the latest ESP-IDF.
Users browsing this forum: Bing [Bot] and 127 guests
