Setting wifi configuration
Ritesh
Contact:
Re: Setting wifi configuration
Postby Ritesh » Fri Dec 28, 2018 6:34 pm
burkulesomesh43 wrote:
Wed Dec 26, 2018 7:41 am
hoainguyen265 wrote:
Tue Dec 25, 2018 7:11 am
I think it just like using wifi on mobile phone. When use want to connect to another wifi, you just disconnect and reconnect. And calling
esp_wifi_start();  esp_wifi_stop()
is the same with disable and enable wifi on mobile phone and doing this periodically is not good.
So in my opinion, if you just want change wifi ssid, just disconnect, set up new wifi ssid and reconnect is good choice.
Heyy, it works without wifi_disconnect. just changed ssid and reconnect.
Yeah. Exactly, We are also doing same thing like changing WiFi configurations and reconnecting WiFi whenever want to switch router or hot-spot as per our requirements.
Regards,
Ritesh Prajapati
burkulesomesh43
Postby burkulesomesh43 » Mon Dec 31, 2018 2:00 pm
Wed Dec 26, 2018 8:37 am
Nice :D
Heyy,
I am getting this error by changing configuration.
183188) wifi: esf_buf: t=2 l=76 max:32, alloc:32 no eb
W (1183188) wifi: alloc eb len=76 type=2 fail, heap:41928
W (1183198) wifi: m f probe req l=0
E (1183318) wifi: esf_buf: t=2 l=76 max:32, alloc:32 no eb
W (1183318) wifi: alloc eb len=76 type=2 fail, heap:41936
W (1183318) wifi: m f probe req l=0
E (1183438) wifi: esf_buf: t=2 l=76 max:32, alloc:32 no eb
W (1183438) wifi: alloc eb len=76 type=2 fail, heap:41936
W (1183438) wifi: m f probe req l=0
E (1183568) wifi: esf_buf: t=2 l=76 max:32, alloc:32 no eb
W (1183568) wifi: alloc eb len=76 type=2 fail, heap:41936
W (1183568) wifi: m f probe req l=0
E (1183688) wifi: esf_buf: t=2 l=76 max:32, alloc:32 no eb
W (1183688) wifi: alloc eb len=76 type=2 fail, heap:41936
Somesh Burkule
Ritesh
Contact:
Postby Ritesh » Tue Jan 01, 2019 8:16 am
Nice :D
Heyy,
As per error logs it seems like memory is going to be leaked at low level of WiFi Stack. Would you please share code like what you have did? so that it will be helpful to give support for that.
Regards,
Ritesh Prajapati
burkulesomesh43
Postby burkulesomesh43 » Tue Jan 01, 2019 10:44 am
Nice :D
Heyy,
I am switching into two networks in handler like this->>
static esp_err_t event_handler(void *ctx, system_event_t *event)
	switch(event->event_id) {
	    case SYSTEM_EVENT_STA_START:
	    	ESP_LOGI("WIFI TEST","SYSTEM_EVENT_STA_START");
	        esp_wifi_connect();
	        break;
	    case SYSTEM_EVENT_STA_CONNECTED:
	    	ESP_LOGI("WIFI TEST","SYSTEM_EVENT_STA_CONNECTED");
	    	tryToConnect=0;
	        break;
	    case SYSTEM_EVENT_STA_GOT_IP:
	    	ESP_LOGI("WIFI TEST ","SYSTEM_EVENT_STA_GOT_IP");
	    	wifi_con_flag=1;
	        xEventGroupSetBits(wifi_event_group, CONNECTED_BIT);
	        break;
	    case SYSTEM_EVENT_STA_DISCONNECTED:
	    	ESP_LOGI("WIFI TEST","SYSTEM_EVENT_STA_DISCONNECTED");
	    	wifi_con_flag=0;
	    	esp_wifi_disconnect();
	    	ESP_LOGI("WIFI TEST ","tryToConnect: %d",tryToConnect);
	    	//connect to set configuration
	    	if(tryToConnect < 10){
	        ESP_LOGI("WIFI TEST ","set configuration");
			memset(&wifi_config, 0, sizeof(wifi_config));
	                strcpy((char *)wifi_config.sta.ssid, "somesh");
	                strcpy((char *)wifi_config.sta.password,"123456" );
			ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
	    	}else if(tryToConnect > 10 && tryToConnect < 15){
	        ESP_LOGI("WIFI TEST ","default configuration");
	                strcpy((char *)wifi_config.sta.ssid, "default");
	        esp_wifi_connect();
	        tryToConnect++;
	        if(tryToConnect == 15)tryToConnect=0;
	        xEventGroupClearBits(wifi_event_group, CONNECTED_BIT);
	        break;
	    default:
	        break;
	    return ESP_OK;
Somesh Burkule
Ritesh
Contact:
Postby Ritesh » Sat Jan 05, 2019 5:20 pm
Heyy,
	        esp_wifi_connect();
	        break;
	    	tryToConnect=0;
	        break;
	    	wifi_con_flag=1;
	        break;
	    	wifi_con_flag=0;
	        esp_wifi_connect();
	        tryToConnect++;
	        break;
	    default:
	        break;
	    return ESP_OK;
Are you getting issue on individual connection test like AP mode or STA mode? Because as per code there is no any issue into switching mechanism.
Regards,
Ritesh Prajapati
burkulesomesh43
Postby burkulesomesh43 » Sun Jan 06, 2019 4:13 am
	        esp_wifi_connect();
	        break;
	    	tryToConnect=0;
	        break;
	    	wifi_con_flag=1;
	        break;
	    	wifi_con_flag=0;
	        esp_wifi_connect();
	        tryToConnect++;
	        break;
	    default:
	        break;
	    return ESP_OK;
Yes I am using STA mode only. that error is rare. it comes sometimes and esp32 is gets stucked and error comes infinitely.
Not getting what is the issue.
Somesh Burkule
Ritesh
Contact:
Postby Ritesh » Sun Jan 06, 2019 6:39 am
	        esp_wifi_connect();
	        break;
	    	tryToConnect=0;
	        break;
	    	wifi_con_flag=1;
	        break;
	    	wifi_con_flag=0;
	        esp_wifi_connect();
	        tryToConnect++;
	        break;
	    default:
	        break;
	    return ESP_OK;
As per error log it indicates that memory is going to be leaked at low level into wifi stack level. So, would you please try to deinit and again init wifi while switching from STA mode to AP mode?
Regards,
Ritesh Prajapati
burkulesomesh43
Postby burkulesomesh43 » Tue Jun 11, 2019 10:45 am
Ritesh wrote:
Fri Dec 28, 2018 6:31 pm
ESP_igrr wrote:
Tue Dec 25, 2018 10:19 am
Since by default Wi-Fi configuration is stored into flash, you may want to call esp_wifi_set_storage function with WIFI_STORAGE_RAM argument. In this case configuration will not be saved in flash, and flash lifetime will not be affected.
We are storing WiFi configurations into flash memory as per our requirements. So, what will be the lifetime of flash operation for single device? Because we are also in same phase like many times WiFi configurations will be changed as per our project requirements.
the limit is 100000 write cycles.
Somesh Burkule
Ritesh
Contact:
Postby Ritesh » Tue Jun 11, 2019 10:58 am
Thanks a lot.
I just want to know that your issue has been resolved or still open?
Regards,
Ritesh Prajapati
burkulesomesh43
Postby burkulesomesh43 » Tue Jun 11, 2019 11:01 am
Thanks a lot.
Resolved.
Somesh Burkule
Users browsing this forum: Google [Bot] and 133 guests
