Schematics of Espressif ESP32 dev boards & modules
Electrical schematic PDFs for development boards & modules designed by Espressif:
Note: This list is no longer updated. Latest reference designs can be downloaded from http://espressif.com/en/support/download/documents
Previously Published Development Boards Modules Older Development Boards The IDF hardware reference documentation also contains links to these schematics:
http://esp-idf.readthedocs.io/en/latest ... index.html
To ask a question about a particular board or module, please start a new thread.
Re: Schematics of Espressif ESP32 dev boards & modules
@ESP_Angus Thanks!
First post is updated with a link to the ESP32 Demo Board V2 schematic.
- ESP_krzychb
- Contact:
Hi ESP_Angus,
Could you post schematic of ESP-WROVER-KIT V2 (black)?
Thanks for the reminder krzychb. Done (link in first post.)
Where can we find a bill of materials (BOM) for some of these boards like the DevKitC? I can see things like S8050 and NCP1117 which are too vague to properly source.
Even worse, I have no idea what a ESD05V88D-LC is, the package size, or which manufacturer makes them.
There is a bill of materials for the ESP32-WROOM-32 module, in the ESP32 Module Reference Design. Unfortunately, no such design documents exist for the DevKitC.
How can I figure out which components to order, if I want to reproduce the DevKitC design by myself?
Line 10 of the bill of materials [1] for the DevKitC specifies 'ESD05V88D-LC,0402' which is not listed on Arrow, Mouser, or DigiKey. It appears it is a 'ESD Suppressor' for USB 5V rails. Which of these parts would be an appropriate replacement?
SD05-7 [2]
SD05-01FTG [3]
SD05-TCT [4]
Unfortunately none of them are 0402 sized, but I'm more worried whether they functionally match the 'ESD05V88D.'
[1] http://www.espressif.com/en/support/dow ... nce+Design
[2] https://www.arrow.com/en/products/sd05- ... orporated/
[3] https://www.arrow.com/en/products/sd05- ... ittelfuse/
[4] https://www.arrow.com/en/products/sd05.tct/semtech/
SD05-7 [2]
SD05-01FTG [3]
SD05-TCT [4]
Check the datasheet and the datasheet/notes of the device it is protecting (cp2102).
Below are three kinds of ESD protection diode that can be as a replacement.
https://www.arrow.com/en/products/esd9b ... iconductor
https://www.arrow.com/en/products/esd9m ... iconductor
https://www.arrow.com/en/products/esd9d ... iconductor
Hi Angus,
I would like to ask for the WROVER module schematic... I would like to see the connections for the SPI FLASH and external PSRAM, would you mnd to post it? the new one with 2 columms distribution!
Regards
Juan
Regards
Juan
Users browsing this forum: Bing [Bot] and 126 guests
