I've upgrade ESP-IDF from v.3.2-beta1 to v.3.3-dev and I've got an error with the linker also with hello-world example:
"linker script generation failed for /esp-idf/components/esp32/ld/esp32.commonld.in
ERROR:
LD build/hello-world.elf
/../../../xtensa-esp32-elf/bin/ld:
cannot open linker script file /esp/hello_world/build/esp32.common.ld: No such file or directory
collect2: error: ld returned 1 exit status"
Some idea?
Best Regards
Re: cannot open linker script file
Could you please run 'make list-components' and paste the output?
I'm facing exactly the same problem ...
I'm also facing exactly the same issue with fa59b1b1c9e9085dde5fb2bbc7610bbdb2289741
I've attach an edited version of make list-components. It has my projects components and pathnames omitted for NDA reasons.
- out.txt
- (3.8 KiB) Downloaded 918 times
Hi all,
Please update to the latest master branch. We've fixed some ldgen linker script generation issues, but also improved the error messages so if still fails there should be more information given about why.
Angus
Angus
Ok, with the last release of the master is fixed.
Users browsing this forum: Baidu [Spider] and 92 guests
