current consumption
fernan0693
current consumption
Postby fernan0693 » Mon Oct 08, 2018 9:10 pm
I have an esp32 ttgo , and i want to know if is normal that when the program runs consume 65 mili amps prox ?
Re: current consumption
Postby ESP_Sprite » Wed Oct 10, 2018 1:56 am
ttgo? But yes, depending on what the ESP32 is doing, that current usage sounds pretty normal.
fernan0693
Postby fernan0693 » Wed Oct 10, 2018 9:33 pm
ok , but the esp32 is the normal consumption in the simply program and It is possible that wake up of the deep sleep Only when ascending enge of the pin?
fernan0693
Postby fernan0693 » Thu Oct 11, 2018 1:10 am
Ok; normally the esp32 when you are running a program that current consumes approximately,
I ask you the esp32 to wake you up from deep sleep you can only with the high and low states or you can get upset with the changes falling or rising?
Postby ESP_Sprite » Thu Oct 11, 2018 2:38 am
No, sorry, we don't have edge-triggered wake up modes. You may be able to do something with the ULP to get something that works, however.
rummyr
Postby rummyr » Mon Oct 22, 2018 4:54 am
When level is high before entering deep sleep, set deep sleep to wake on level low.
When level is low, set deep sleep to wake on level high.
Would that work for you?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 121 guests
