Have one question. I made successfully ESP32 safe boot + flash encryption work on devkit (ESP-WROOM-32). Now i tried to make it work on ESP32-WROWER. I wrote the keys as previously on devkit. The same with the fuses. But the HW bootloader still not found the software bootloader (flash read error , 1000). I compared the fuses with devkit and found that WROWER have set the CODING_SCHEME efuse to 0x01 (it means all the key register blocks are used in 3/4 encode mode). Can you recommend me, how to calculate the encryption key? Here are the fuses:
DEVKIT FUSES:
espefuse.py v2.3.1
Connecting.....
Security fuses:
FLASH_CRYPT_CNT Flash encryption mode counter = 7 R/W (0x7)
FLASH_CRYPT_CONFIG Flash encryption config (key tweak bits) = 15 R/W (0xf)
CONSOLE_DEBUG_DISABLE Disable ROM BASIC interpreter fallback = 1 R/W (0x1)
ABS_DONE_0 secure boot enabled for bootloader = 1 R/W (0x1)
ABS_DONE_1 secure boot abstract 1 locked = 0 R/W (0x0)
JTAG_DISABLE Disable JTAG = 1 R/W (0x1)
DISABLE_DL_ENCRYPT Disable flash encryption in UART bootloader = 1 R/W (0x1)
DISABLE_DL_DECRYPT Disable flash decryption in UART bootloader = 1 R/W (0x1)
DISABLE_DL_CACHE Disable flash cache in UART bootloader = 1 R/W (0x1)
BLK1 Flash encryption key
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -/-
BLK2 Secure boot key
BLK3 Variable Block 3
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Efuse fuses:
WR_DIS Efuse write disable mask = 384 R/W (0x180)
RD_DIS Efuse read disablemask = 3 R/W (0x3)
CODING_SCHEME Efuse variable block length scheme = 0 R/W (0x0)
KEY_STATUS Usage of efuse block 3 (reserved) = 0 R/W (0x0)
Config fuses:
XPD_SDIO_FORCE Ignore MTDI pin (GPIO12) for VDD_SDIO on reset = 0 R/W (0x0)
XPD_SDIO_REG If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset = 0 R/W (0x0)
XPD_SDIO_TIEH If XPD_SDIO_FORCE & XPD_SDIO_REG, 1=3.3V 0=1.8V = 0 R/W (0x0)
SPI_PAD_CONFIG_CLK Override SD_CLK pad (GPIO6/SPICLK) = 0 R/W (0x0)
SPI_PAD_CONFIG_Q Override SD_DATA_0 pad (GPIO7/SPIQ) = 0 R/W (0x0)
SPI_PAD_CONFIG_D Override SD_DATA_1 pad (GPIO8/SPID) = 0 R/W (0x0)
SPI_PAD_CONFIG_HD Override SD_DATA_2 pad (GPIO9/SPIHD) = 0 R/W (0x0)
SPI_PAD_CONFIG_CS0 Override SD_CMD pad (GPIO11/SPICS0) = 0 R/W (0x0)
DISABLE_SDIO_HOST Disable SDIO host = 0 R/W (0x0)
Identity fuses:
MAC MAC Address
= 30:ae:a4:08:99:78 (CRC b5 OK) R/W
CHIP_VER_REV1 Silicon Revision 1 = 1 -/W (0x1)
CHIP_VERSION Reserved for future chip versions = 0 -/W (0x0)
CHIP_PACKAGE Chip package identifier = 0 -/W (0x0)
Calibration fuses:
BLK3_PART_RESERVE BLOCK3 partially served for ADC calibration data = 0 -/W (0x0)
ADC_VREF Voltage reference calibration = 1100 -/W (0x0)
Flash voltage (VDD_SDIO) determined by GPIO12 on reset (High for 1.8V, Low/NC for 3.3V).
WROWER fuses:
espefuse.py v2.3.1
Connecting........_
Security fuses:
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 91 12 10 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Efuse fuses:
CODING_SCHEME Efuse variable block length scheme = 1 R/W (0x1)
Config fuses:
Identity fuses:
MAC MAC Address
= b4:e6:2d:c8:0a:6d (CRC 79 OK) R/W
CHIP_VERSION Reserved for future chip versions = 2 -/W (0x2)
Calibration fuses:
BLK3_PART_RESERVE BLOCK3 partially served for ADC calibration data = 1 -/W (0x1)
ADC_VREF Voltage reference calibration = 1072 -/W (0x14)
ADC1_TP_LOW ADC1 150mV reading = 342 R/W (0x10)
ADC1_TP_HIGH ADC1 850mV reading = 3409 R/W (0x24)
ADC2_TP_LOW ADC2 150mV reading = 489 R/W (0x11)
ADC2_TP_HIGH ADC2 850mV reading = 3482 R/W (0x13)
