Hi all
i am working with esp/idf example "gatt_security_server"
i have got the feature of pass key which is required to access the BLE device. following are mz questions
1. who is generating this passkey ? sometime it is 5 digit sometime 6 ? can i have my own passkey ? for paring the device ?
2, what is exactly happening in encryption of BLE ? SMP ?
3, to see the passkey i always need to monitor my device which is not good option for all the time. it is possible to define the passkey once for parring ?
thanks
the passkez in BLE security
Re: the passkez in BLE security
1. SMP stack (usually on server) is generating passkey; when i studied bt specs some time ago ive read it should be 6 digit passkey, but it seems to be 5-6 digits; when server is keypad only and client device is display then client device SMP is generating passkey; but to be honest im not 100% certain
3. https://esp32.com/viewtopic.php?f=13&t=6877
or you can use bonding/pairing without passkey and during pairing add device to whitelisted, finally you can allow to connect only whitelisted devices. For example you will need just one gpio/button, when its high on esp32 startup then you will allow to connect and pair new device and when its low - connect only whitelisted.
Hi chegewara,chegewara wrote: or you can use bonding/pairing without passkey and during pairing add device to whitelisted, finally you can allow to connect only whitelisted devices. For example you will need just one gpio/button, when its high on esp32 startup then you will allow to connect and pair new device and when its low - connect only whitelisted.
do you have an example for this? I'm trying something similar like this but on arduino platform.
greetz
Users browsing this forum: No registered users and 82 guests
