UDP Support
born2make.happy
UDP Support
Postby born2make.happy » Mon Aug 06, 2018 10:41 am
i want to know can anyone planning to add UDP Support alternatively then HTTP
Re: UDP Support
Postby ESP_Sprite » Tue Aug 07, 2018 3:31 am
Your question doesn't make much sense to me, sorry. UDP is supported using the standard Posix socket API, and I'm not sure how UDP could be an alternative to HTTP...
fly135
Re: UDP Support
Postby fly135 » Tue Aug 07, 2018 1:05 pm
HTTP is implemented by TCP, not UDP. Nobody supports HTTP over UDP.
John A
born2make.happy
Re: UDP Support
Postby born2make.happy » Fri Aug 10, 2018 9:24 am
I need to know Like HTTP streaming i want UDP Streaming..
Re: UDP Support
Postby ESP_Sprite » Sat Aug 11, 2018 2:40 am
That does not make sense; UDP is packet-based (without guaranteed delivery or reordering prevention) so per definition not a stream. Can you expand a bit more on what you're actually trying to do? As in: can you describe the project you're trying to use this for, and why you think you need UDP instead of HTTP (or something else, like raw TCP sockets)?
fly135
Re: UDP Support
Postby fly135 » Sat Aug 11, 2018 4:26 pm
born2make.happy wrote:I need to know Like HTTP streaming i want UDP Streaming..
1) Create a datagram socket
optional) Bind it to an interface, or call connect to set target address.
2) Call sendto over and over.
Now you are streaming datagram packets.
Users browsing this forum: No registered users and 177 guests
