Where can I found the openOCD interface file for ESP-Prog?
Super169
Postby Super169 » Fri Aug 03, 2018 2:52 am
I just bought the ESP-Prog for debugging the ESP32 sketch.
I have follow the step here to config for JTAG Debugging (http://esp-idf.readthedocs.io/en/latest ... ndex.html#)
When I go to the step to Run OpenOCD, it need to provide the interface file, I can find some interface files in openocd\scripts\interface & openocd\scripts\interface\ftdi.
But I don't know which one is suitable for ESP-Prog, there does not have a cfg with the name like ESP-Prog.
Does anyone know where I can get the interface file to ESP-Prog, or which of the existings interface file can be used?
Thanks a lot!
lkuchars
Re: Where can I found the openOCD interface file for ESP-Prog?
Postby lkuchars » Mon Jan 21, 2019 5:28 pm
I know it might be too late for this now but on one of the links from page you mentioned earlier there's an example:
cd ~/esp/openocd-esp32
bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
the second -f argument you need to change of course if you're using different board.
cheers
Lukas
Users browsing this forum: No registered users and 119 guests
