How can I setup a software breakpoint?
dzRBRglobal
Postby dzRBRglobal » Thu Jul 26, 2018 8:22 pm
From this link : https://github.com/espressif/openocd-esp32/issues/45
It seems the latest openocd ESP32 supports software breakpoint. Anybody has tried it?
ESP_igrr
Re: How can setup a software breakpoint?
Postby ESP_igrr » Thu Jul 26, 2018 8:41 pm
An update to JTAG debugging guide in IDF is in progress, but for now you can keep using OpenOCD as you used it in the past, and it will allow you to set more breakpoints. Previously the limit was 2 hardware breakpoints, and now the limit is 2 hardware + 32 software breakpoints in Flash + 32 software breakpoints in IRAM.
dzRBRglobal
Postby dzRBRglobal » Thu Jul 26, 2018 9:26 pm
ESP_igrr wrote:An update to JTAG debugging guide in IDF is in progress, but for now you can keep using OpenOCD as you used it in the past, and it will allow you to set more breakpoints. Previously the limit was 2 hardware breakpoints, and now the limit is 2 hardware + 32 software breakpoints in Flash + 32 software breakpoints in IRAM.
Thank you very much for the clarification. I just setup the esp development environment on a ubuntu virtual machine. I am very new to openocd and gdb. I installed the eclipse as my coding front end. And use the GNU MCU ECLIPSE plugin to call openocd and gdb. Now code complies and debug properly on my setup. The only problem is if I add more than two breakpoints, openocd will complain
Warn : xtensa_add_breakpoint: max slot reached, slot=2
Error: can't add breakpoint: resource not available
I havent tried to directly use commend line with openocd yet. I ll try tomorrow see if commend line allows me to add more breakpoints
dzRBRglobal
Re: How can I setup a software breakpoint?
Postby dzRBRglobal » Thu Jul 26, 2018 9:40 pm
here is a screen shot of the error message
ESP_igrr
Postby ESP_igrr » Fri Jul 27, 2018 7:11 am
Please follow instructions listed here to generate OpenOCD log file: https://docs.espressif.com/projects/esp ... ing-issues
Then upload the log file here or to GitHub issue tracker https://github.com/espressif/openocd-esp32/issues/. Thanks.
dzRBRglobal
Postby dzRBRglobal » Fri Jul 27, 2018 6:13 pm
Hi igrr,
Thank you very for your immediate reply. I will follow the instruction and upload the log.
dzRBRglobal
Postby dzRBRglobal » Fri Jul 27, 2018 7:00 pm
ESP_igrr wrote:Please follow instructions listed here to generate OpenOCD log file: https://docs.espressif.com/projects/esp ... ing-issues
here is a link to GitHub issue: https://github.com/espressif/openocd-esp32/issues/51
I also attached the logs
openocd_log.txt
(1.27 MiB) Downloaded 961 times
gdb_log.txt
(31.53 KiB) Downloaded 948 times
dzRBRglobal
Postby dzRBRglobal » Mon Jul 30, 2018 1:37 pm
as gerekon metioned in this link:
After I update my openocd to 2018-07-24 the problem is fixed. :)
Users browsing this forum: No registered users and 180 guests
